Power issues with the propeller control board — Parallax Forums
jamesvwestonjamesvweston Posts: 16
edited 2009-02-28 20:25 in Propeller 1
I'm not sure what is going on with my prop board, but it appears that there is a power issue.
When I try to hook it up to my computer via USB, I'll do a port scan in the Propeller Tool to try to detect that its connected, and get this error:
"No propeller chip found on any serial port"
I've tested this on a few computers, and its the same results.
No changes have been made to the way the power pack is installed to the board, and I'm sure that the wires from the power pack are fastened
tightly to the board.
I know that the board is getting at least some power because the on-board blue LED turns on when I power the board up.
Any help would be appreciated,
-Jimmy
  • jamesvwestonjamesvweston Posts: 16
    edited 2009-02-26 20:51
    Oh, and the batteries are fresh, straight from the pack.
    I've made that mistake a time or two and have learned from it haha [noparse]:)[/noparse]
    edited 2009-02-26 20:58
    You have to have the proper USB driver installed. You can download the FTDI USB driver from Parallax (www.parallax.com/Default.aspx?tabid=530) or from FTDI's website (www.ftdi.com).
    edited 2009-02-26 21:10
    Already had those installed. I tried reinstalling, and rebooted my computer. Same issue as above.
    Also, I'm using a Propeller Plug
    edited 2009-02-26 22:09
    I'm beginning to think that it may be an issue with my Prop Plug, or the connection on the board for the prop plug.
    However, it hasn't really been used a whole lot, and has been well taken care of.
    Can you think of any ideas to test it out? Whenever I try to initiate communications from the computer its plugged into,
    the a blue light will flash....but that is what has always happened.
  • OlovAOlovA Posts: 23
    edited 2009-02-26 22:31
    Hi. r u sure u dont put the prop plug upside down ? The led's should be down...
    Yup I'm sure its set up correctly. When I first got it I made that mistake haha
    I was right in the middle of a project, so this is very annoying. I'm posting some additional information. Hopefully something will click and someone will be able to recognise the problem.
    1) I unplugged the prop plug from the propeller control board. I plugged the USB cable into my computer, and attached the other end to the prop plug. The computer recognised the
    device and the lights on the plug flashed.
    2) There is no physical damage that has been done to either the prop plug or the propeller control board.
    3) There is a fresh battery pack hooked up to the propeller control board.
    4) When I turn the propeller control board on (in either mod, servos on or servos off) the on board blue LED turns on.
    5) The prop plug still fits snuggly onto the prop control board.
