Powering stamp advice
I know you can power the BS2 with 5v - 15v through VIN, so I decided for my automotive circuit that I could just power the stamp directly to the car's battery. When the alternator kicks on the voltage at most about 14.5 volts. Is this a good or bad idea. I am a little iffy about it because it pushes the stamps requirement just under the 15v mark. If this is too much for the BS2, would a 5v regulator be better on board my circuit? Thanks.
