Display word VAR on LCD? — Parallax Forums
Alex41Alex41 Posts: 112
edited 2009-03-01 20:26 in General Discussion
Hello,
Below is a program that I wrote to display variables on an LCD. The program is simple to·solve my problem before adding more code. It has been modified from the LCD program online describing use of the Parallax LCD so it is not all my original programming.smile.gif
I'm trying to display a word value on the LCD. I understand the LCD_DEC3 subroutine, it displays a byte. I tried to add additional code to add the 1000's digit, but the compiler truncates the last "0" of "1000".
I have a pot on my board which I read and can adjust to give me different values to display.
As the code is written I tried to break up the word variable into MSB and LSB and display each byte individually. That isn't working because the LSB rolls over above 255 back to 0 instead of up to 999 then rolling over to 0. I do understand why it does this, but not sure how to fix it.
Any help to point me in the right direction?
Display a word variable as a string somehow?
Alex
'   File...... LCD - MineR2.SXB
'   Purpose... Display of variables to the Parallax Serial LCD with SX/B
'   Author.... Alex41
'   E-mail....
'   Started... Feb 01 2009
'   Updated... Feb 22 2009
' Program Description
' runs on SX/B 1.50.01
' R1
' Program displays an output of a value of a pot using RCTIME to an LCD
' R2
' Try to display Word variables
' Device Settings
DEVICE          SX48, OSCXT2
FREQ            4_000_000
' IO Pins
LcdTx  PIN RC.7   ' LCD serial connection
PotPin  PIN RA.0   ' pin for RCTIME
OUTPUT  RA
' Constants
LcdBaud  CON "T19200"  ' or T2400, or T9600
LcdBkSpc        CON     $08              ' move cursor left
LcdRt           CON     $09              ' move cursor right
LcdLF           CON     $0A              ' move cursor down 1 line
LcdCls          CON     $0C              ' clear LCD (need 5 ms delay)
LcdCR           CON     $0D              ' move pos 0 of next line
LcdBLon         CON     $11              ' backlight on
LcdBLoff        CON     $12              ' backlight off
LcdOff          CON     $15              ' LCD off
LcdOn1          CON     $16              ' LCD on; no crsr, no blink
LcdOn2          CON     $17              ' LCD on; no crsr, blink on
LcdOn3          CON     $18              ' LCD on; crsr on, no blink
LcdOn4          CON     $19              ' LCD on; crsr on, blink on
LcdLine1        CON     $80              ' move to line 1, column 0
LcdLine2        CON     $94              ' move to line 2, column 0
' Variables
idx1  VAR     Byte   ' loop control
char            VAR     Byte
newChar         VAR     Byte
pos  VAR Byte   ' position
counter  VAR Byte
tmpB1  VAR Byte   ' subroutine work vars
tmpB2  VAR Byte
tmpB3  VAR Byte
tmpB4  VAR Byte
tmpW1  VAR Word
Pottime  VAR Word   ' var for RCTIME
Potw  VAR Word
  PROGRAM Start
' Subroutine Declarations
DELAY_MS SUB 1, 2   ' delay in milliseconds
DELAY_US        SUB     1, 2   ' delay in microseconds
LCD_OUT  SUB 1   ' byte to LCD
LCD_STR  SUB 2   ' string to LCD
LCD_DEC3 SUB 1   ' print using DEC3 format
' Program Code
Start:
  'PLP_A = %00000000    ' pull up unused pins
  PLP_B = %00000000
  PLP_C = %00000000
  PLP_D = %00000000
  PLP_E = %00000000
  HIGH LcdTx
  DELAY_MS 100     ' let LCD initialize
Main:
  LCD_OUT LcdBLon    ' backlight off
  LCD_OUT LcdOn1    ' no cursor or blink
  LCD_OUT LcdCls    ' clear the LCD
  DELAY_MS 250
DO
  HIGH potpin   ' charge the capacitor
  PAUSEUS 300   ' Pause for 300 us
  RCTIME Potpin, 1, Pottime ' measure in 2 us units
  Pottime = Pottime * 4  ' makes the RCTIME result bigger
  LCD_OUT LcdLine1
  LCD_STR "Pot - "
  LCD_DEC3 Pottime_MSB  ' display RCTIME result
  LCD_DEC3 Pottime_LSB
  DELAY_MS 100   ' delay to make output readable
LOOP
  GOTO Main
' Subroutine Code
' Use: DELAY_MS milliseconds
SUB DELAY_MS
  IF __PARAMCNT = 1 THEN
    tmpW1 = __PARAM1                            ' save byte value
  ELSE
    tmpW1 = __WPARAM12                          ' save word value
  ENDIF
  PAUSE tmpW1
  ENDSUB
' Use: DELAY_US microseconds
DELAY_US:
   ELSE
   ENDIF
   PAUSEUS tmpW1
RETURN
' Use: LCD_OUT aByte
' -- "aByte" is single-byte constant or variable
SUB LCD_OUT
  SEROUT LcdTx, LcdBaud, __PARAM1
  ENDSUB
' Use: LCD_STR [noparse][[/noparse] string | label ]
' -- "string" is an embedded literal string
' -- "label" is DATA statement label for stored z-String
SUB LCD_STR
  tmpW1 = __WPARAM12    ' save address
  DO
    READINC tmpW1, tmpB1
    IF tmpB1 = 0 THEN EXIT                  ' if 0, string complete
    LCD_OUT tmpB1
  LOOP
  ENDSUB
' Use: LCD_DEC3 value
' -- displays byte value in DEC3 format
SUB LCD_DEC3
  tmpB2 = __PARAM1    ' copy output value
  tmpB2 = tmpB2 / 100    ' get 100's digit
  tmpB3 = __REMAINDER    ' save 10's & 1's
  tmpB1 = "0" + tmpB2    ' make 100's character
  LCD_OUT tmpB1     ' print it
  tmpB2 = tmpB3 / 10    ' get 10's digit
  tmpB3 = __REMAINDER    ' save 1's
  tmpB1 = "0" + tmpB2    ' make 10's character
  tmpB1 = "0" + tmpB3    ' make 1's character
  ENDSUB
' Program Data
If at first you don't succeed, then skydiving is not for you.
  • BeanBean Posts: 8,129
    edited 2009-02-25 16:04
    Alex,
    · SX/B 2.0 has a STR command that will take a WORD variable and create an array of characters that you can send to the LCD.
    · I'd suggest downloading SX/B 2 and using the STR command.
    You can download it from this thread: http://forums.parallax.com/showthread.php?p=780347
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
  • Alex41Alex41 Posts: 112
    edited 2009-02-25 16:15
    Bean,
    Thanks for the help.
    I've been lurking lately and·seen that·2.0 is out. I guess this will get me to install it. I'll give it a try.
    Alex
  • JonnyMacJonnyMac Posts: 9,759
    edited 2009-02-25 16:24
    This should get you going. You'll need to define a 5-byte array called nStr.
    LCD_DEC         SUB     1, 3
    ' Use: LCD_DEC value {, digits }
    ' -- prints "value" in DEC format
    ' -- "digits" MUST be specified with word values
    ' -- DEC3 or DEC5 format is used if "digits" not specified or invalid
    SUB LCD_DEC
      dValue        VAR     tmpW1
      dDigits       VAR     tmpB1
      dIdx          VAR     tmpB2
      dChar         VAR     __PARAM1
      IF __PARAMCNT = 1 THEN                        ' byte w/o digits
        dValue = __PARAM1
        dDigits = 3
      ELSEIF __PARAMCNT = 2 THEN                    ' byte w/digits
        dValue = __PARAM1
        dDigits = __PARAM2
      ELSE                                          ' word w/digits
        dValue = __WPARAM12
        dDigits = __PARAM3
      ENDIF
      IF dDigits = 0 THEN                           ' validate digits
        dDigits = 5
      ELSEIF dDigits > 5 THEN
        dDigits = 5
      ENDIF
      STR nStr, dValue                              ' to decimal string
      dIdx = 5 - dDigits                            ' point to first char
      DO WHILE dIdx < 5
        LCD_OUT nStr(dIdx)
        INC dIdx
      LOOP
      ENDSUB
    edited 2009-02-25 16:29
    JonnyMac,
    Thanks for the code! That's a big help.
    I see it is for 2.0 by the local variables in the subroutine. I'll install 2.0 and get up to speed on the new features.
    Alex
    edited 2009-02-25 16:38
    Be careful with locals as they add a lot of [noparse][[/noparse]necessary] overhead -- use sparingly (just my opinion)
    edited 2009-03-01 12:46
    JonnyMac,
    I just upgraded to 2.0 and used your code from above.
    It works perfectly!
    Alex
    Glad it works -- but with SX/B 2.00.16 it gets even better. By having the compiler promote bytes to words for a sub/func call we can now use the __PARAMCNT to determine whether we want a fixed-with field (width is specified in the call) or a variable-width field based on the value. Try this one:
    LCD_DEC         SUB     2, 3, Word, Byte
    ' Use: LCD_DEC value {, digits}
    ' -- print value in decimal format
    ' -- if digits not specified field width automatically adjusted
    ' -- field is space padded (no leading zeroes)
    SUB LCD_DEC
      '{$IFUSED LCD_DEC}
      dcValue       VAR     tmpW1                   ' value to print
      dcDigits      VAR     tmpB3                   ' # digits to print
      dcValue = __WPARAM12
      IF __PARAMCNT = 3 THEN
        dcDigits = __PARAM3                         ' get width
        dcDigits = dcDigits MAX 5                   ' make sure it's legal
        dcDigits = dcDigits MIN 1
      ELSE                                          ' adjust field for value
        IF dcValue > 9999 THEN
          dcDigits = 5
        ELSEIF dcValue > 999 THEN
          dcDigits = 4
        ELSEIF dcValue > 99 THEN
          dcDigits = 3
        ELSEIF dcValue > 9 THEN
          dcDigits = 2
        ELSE
          dcDigits = 1
        ENDIF
      ENDIF
      STR nStr, dcValue                             ' create decimal string
      dcDigits = 5 - dcDigits                       ' convert to string index
      DO UNTIL dcDigits = 5                         ' print the value
        LCD_OUT nStr(dcDigits)
        INC dcDigits
      LOOP
      '{$ENDIF}
      ENDSUB
    Post Edited (JonnyMac) : 3/1/2009 8:33:54 PM GMT
