@ Terry..... SX/B 14 Broken?/ Not Understood? — Parallax Forums
pjvpjv Posts: 1,903
edited 2009-02-25 21:49 in General Discussion
Hi Terry;
I'm trying SX/B version 14, and now my subs which were previously working won't compile. Perhaps I'm just not using the new features properly, but I believe the (optional?) word/byte modifiers for passing variables would be done in the sub definition. I use a lot of assembly subs and prefacing them with the modifiers does not work.
Am I wrong, and·must the modifiers be used in every instance the sub is called? If that is the case, then I think we may have gone a step backwards in utility as that becomes very verbose.
I was happy with the WCON construct of version 13. that is what my present code now uses, and it works well.
Mybe I'm not understanding something??
Cheers,
Peter (pjv)
Post Edited (pjv) : 2/25/2009 5:49:27 AM GMT
  • JonnyMacJonnyMac Posts: 9,809
    edited 2009-02-25 07:02
    I'm with you, Peter -- something changed and I don't quite understand, either.
    I'm also wondering how to properly define a function that returns something but expects nothing, e.g.:
    RX_BYTE FUNC 1, 0
    is how I used to do it. This worked in xx.13:
    RX_BYTE FUNC 1, 0, 0, Byte
    ... but doesn't work in xx.14. What is the proper way to use the new syntax with this type of function?
    [noparse][[/noparse]Edit] Even original-style definitions don't work in .14 (maybe that's what Peter meant).
    Post Edited (JonnyMac) : 2/25/2009 7:26:44 AM GMT
  • BeanBean Posts: 8,129
    edited 2009-02-25 12:45
    Peter, No you don't specify the modifiers at each call. Something is amiss...
    Okay, I'll check it out. I completly changed the code that parses the parameters, so I probably have something messed up in there.
    Any more examples that don't work ? It will help me make sure it's right.
    [noparse][[/noparse]EDIT] Okay I found a problem (hopefully THE problem) the compiler is thinking there is 1 parameter when there is zero. So that's why the "Invalid Number of Paramters" error. I will fix this in a jiffy and post version 15. Peter, let me know if this clears up the issues you are having.
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    Post Edited (Bean (Hitt Consulting)) : 2/25/2009 12:59:11 PM GMT
    edited 2009-02-25 15:12
    Terry: That seemed to fix my RX_BYTE function -- will run other code through it.
    [noparse][[/noparse]Edit] Okay, a bigger program seems to be working fine. Just a clarification on the "What's New" information: __PARAMCNT is only used when the sub or func allows a variable number of parameters; when the parameter count is fixed __PARAMCNT is not modified before the call hence is not useful (or needed) by the sub or func.
    Post Edited (JonnyMac) : 2/25/2009 3:24:57 PM GMT
    edited 2009-02-25 15:38
    Jon, Cool. Good catch on the __PARAMCNT error in the pdf. I will fix that right now.
    Peter, let me know if 15 fixes your issues also.
    Bean.
  • pjvpjv Posts: 1,903
    edited 2009-02-25 16:45
    Hi Terry;
    With version 15, I still can't get it to go. Here are my details:
    FReportTimer    con $0403    [url=mailto:'@3/4]'@3/4[/url]
    WriteFRAM  SUB 4
    WriteFram FReportTimer, @ReportTimer, 3      'THIS THROWS AN "INVALID NUMBER OF PARAMETERS" ERROR,whether the next line here specifying the size of each parameter is included or not
    {WriteFRAM: sub word, byte, byte}         'adding or deleting this line still will not copile
       ASM  ;Param1 = byte addr in page;  Param2 = Page address;  Param3 = ram source address;  Param4 = qty to read
    WriteFRAMa mov  w,#%1010_0000 ;write FRAM command
       skip     ;
    WriteRTC mov  w,#%1101_0000 ;write RTC command
       setb DC    ;also send byte address from Param1
       call @__SendCommand ;output WRITE command with page address and byte address to I2C
    WritI2CLoop mov  fsr,__Param3 ;point to source data
       mov  __Param5,ind ;transfer to the shifter
       mov  fsr,#$10  ;restore to SX/B running half
       call @__Param5ToI2C ;shift it out
       inc  __Param3  ;next ram location
       decsz __Param4  ;decrement loop counter
       jmp  @WritI2CLoop ;
       call @__StopI2C  ;
       mov  fsr,#$10  ;
       retp     ;
       ENDASM     ;
    {endsub}              'this line is included when the parameter specification line is included
    WriteFram 0, FReportTimer, @ReportTimer, 3 '  adding the dummy zero parameter with no type specifiers allows the sub to compile
    Version 13 and not having any parameter type definitions (I mean the first line defining the sub) compiled OK.
    With version 14 or 15, and using the 16 bit defined constant FReportTimer, it will not compile.
    If I add an 8 bit·dummy parameter (the 0 in this case) it will compile.
    It appears that it is treating the 16 bit constant as a single 8 bit parameter instead of two eight bit parameters.
    When I substitute the 16 bit parameter FReportTimer·defined with a constant defined using the new WCONST construct, then it will compile.
    I know my explanation and examples are a little convoluted, but I hope this helps. I can spend more time creating scenarios if you need it.
    Also, for clarity, I think it would be good if we could use some terminology that clearly specifies whether· 8 bit, 16 bit, 24 bit and 32 bit constants all are 1 parameter, or 1,2,3,4 parameters. The line
    ····· WriteFram FReportTimer, @ReportTimer, 3
    looks like 3 parameters (or 3 place holders), but with FReportTimer being 16 bits, it is actually 4 bytes that are enumerated.
    Cheers,
    Peter (pjv)
    edited 2009-02-25 17:50
    Peter,
    Okay, I see the problem. The WORD constant is only being counted as 1 bytes (even though it is two).
    I have fixed that and posted version 16.
    Also the parameter specifiers go in the SUB or FUNC declaration, as in:
    DEVICE SX28, OSC4MHZ
    FREQ 4_000_000
    FReportTimer    CON $0403    [url=mailto:'@3/4]'@3/4[/url]
    ReportTimer     VAR BYTE (3)' This is a guess ???
    WriteFRAM  SUB 4,4,WORD,BYTE,BYTE
    PROGRAM Start NOSTARTUP
    Start:
    END
    SUB WriteFRAM
       ENDASM     ;
    ENDSUB
    · Let me know if 16 fixes the issue.
    Bean.
    edited 2009-02-25 20:49
    Terry;
    YOU'RE THE MAN!
    That fixed it, many thanks.
    Cheers,
    Peter (pjv)
  • John CoutureJohn Couture Posts: 370
    Hey guys, we don't say it enough but thank you for taking care of the bugs that would have stumped us newbies for days. Look at the time line on this one. From 9:44pm to about 1pm the next day and Terry created and tested two compiler releases. Now THAT's SERVICE!
    John J. Couture
    San Diego Miramar College
