Is it possible to compare bits? — Parallax Forums
markaericmarkaeric Posts: 282
edited 2009-02-27 05:17 in General Discussion
Hello,
I've been working on a little program where I am putting various bit data into the same variable (to save space), and then trying to compare them.
Apparently the sx-key assembler did not like the following piece of code, or others like it:
cje encbits.0, encbits.1, encAcountAddTwo
what I was hoping to accomplish with the above line was to compare bit 0 and bit 1 from variable 'encbits', then jump to the label 'encAcountAddTwo' if they were the same.
Mark
  • ZootZoot Posts: 2,227
    edited 2009-02-24 23:13
    You can't compare bits per se. In SX/B you could do this as simple IF/THEN. In ASM you need to do something like this (alternatively, you could do mask work; really depends on final needs):
    ' compare tmp1.5 and tmp2.2
    MOV W, #0 ' clear W
    SNB tmp1.5 ' if tmp1.5 = 1 then...
    OR W, #%01 ' set bit 0 of W
    SNB tmp2.2  ' if tmp2.2 = 1 then...
    OR W, #%10 ' set bit 1 of W
    ' so now you've got a 2 bit number in W; if it's 0, no bits set, if 2 both bits set, etc.
    ' obviously there are a million variations you could do here, just remember you can
    ' OR and AND and XOR literals onto W but not ADD literals
    ' this would set W to 0 unless both bits are set (this is an AND), 1 otherwise
    MOV W, #1 ' presume both set
    SB tmp1.5 ' if tmp1.5 = 0 then...
    MOV W, #0 ' clear W
    SB tmp2.2  ' if tmp2.2 = 0 then...
    MOV W, #0 ' clear W
    JZ :neitherbit
    :bothbits
      ' do something
       JMP :done
    :neitherbit
      ' do something
    :done
    edited 2009-02-24 23:18
    Or this.... this only works if it's two adjacent bits (or bits with same index)....
    ' compare myByte.0 and myByte.1
    MOV W, >>myByte ' get bit1 into bit0 in W
    XOR W, myByte ' now XOR with orig. bit0 in myByte; if they are different, bit0 = 1
    AND W, #%0000_0001 ' but mask off the other irrelevant bits in W
    JZ :notdifferent ' if 0, they are same as last time
    :different
       'do something
       JMP :done
    :notdifferent
       ' do something
    :done
  • Peter VerkaikPeter Verkaik Posts: 3,956
    If the bitpositions are 1 apart, as in this case,
    mov w,>>encbits· 'mov b1 into b0 of w
    xor w,encbits····· 'compare with b0 of encbits
    and w,#1·········· 'extract bit, zero if equal
    snz
    jmp encAcountAddTwo
    regards peter
  • markaericmarkaeric Posts: 282
    edited 2009-02-24 23:59
    Thanks for the responses!
    Whew, it looks like it's going to be a bit tricky, as I am using cje, cjne, and cja quite a lot! This is my first attempt at writing a program in assembly, so i'm sure there is a more efficient way I could do things. I suppose I could try doing some trickery with masks, but I wonder if that's truly the best way to go. Also, currently all the bits I'm comparing with one another are not necessarily next to each other, perhaps I could rearrange them.
    Yikes! Just reviewing my code, I noticed a large omission, so perhaps I just need to rewrite the entire program with these concepts in mind [noparse]:([/noparse]
    I suppose I could just write it in C or basic (neither of which I'm proficient in though), but then I won't get the strange pleasure obtained from the challenge of assembly.
  • BeanBean Posts: 8,129
    edited 2009-02-25 00:56
    Here is what SX/B generates:
      CLR __PARAM1                   ;  IF tempb1 = tempb2 THEN Start
      ADDB __PARAM1,tempb1
      ADDB __PARAM1,tempb2
      JNB __PARAM1.0,@Start
    · It's not pretty, but it works.
    Bean
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
    edited 2009-02-25 01:26
    Is the following code ugly? lol
    I ended up creating a new variable 'TestBits' which I will reuse throughout the program. I will just move the desired bits into it, then just compare the entire byte value which I have full control of. By my logic, if encbits 0 and 1 are both zero, then when I test them against 0, if the statement is true, it will jump to the appropriate label. Same thing if they're both 1, then I just compare the 'testbits' variable with 3. Is this really inefficient?
    A_1_CngStateSub ;Sub for calculating Enc_A_count var if Enc A ch.1 changed state
    clr TestBits
    movb testbits.0, encbits.0
    movb testbits.1, encbits.1
    cje testbits, #0, :encAcountAdd
    cje testbits, #3, :encAcountAdd
    :encAcountSub
    dec Enc_A_count
    jmp :End_A1_cngState
    :encAcountAdd
    inc Enc_A_count
    :End_A1_cngState
    ret
  • JonnyMacJonnyMac Posts: 9,558
    edited 2009-02-25 02:01
    Bean's code does what you want, albeit a tiny bit more efficiently. Using your vars:
    Encoder:
      CLR   testBits
      ADDB  testBits, encBits.0
      ADDB  testBits, encBits.1
      JNB   testBits.0, :encAcountAdd
    :encAcountSub
      DEC   Enc_A_count
      SKIP
    :encAcountAdd
      INC   Enc_A_count
    :End_A1_cngState
      RET
    This works because if both bits are 0 or 1 tempBits.0 will be 0.
    [noparse][[/noparse]Edit] The jump out of encAcountSub is jumping over one instruction (INC) so SKIP can be used.
    Post Edited (JonnyMac) : 2/25/2009 4:34:08 AM GMT
    edited 2009-02-25 03:24
    Ohhhhhhh! I see what's happening now! I didn't even remember the addb instruction, and I certainly would not have thought of JNB testBits.0, :encAcountAdd
    Thanks for the help, everyone!
    edited 2009-02-26 04:19
    While this next question isn't exactly related to my original one, it is related to my project, and I didn't really want to start a new thread. Hopefully someone can enlighten me.
    I'm considering interfacing a device such as a "transmissive photomicrosensor" by omron. Looking at datasheets for various models, it's confusing me, so I want someone to give me some insight as to whether I'm on the right track, or not. If not, what am I missing?
    http://www.components.omron.com/components/web/pdflib.nsf/0/0ADB48765B0912AD85257201007DD5D8/$file/24_sx1035_0607.pdf
    There's a tiny usage schematic on the bottom right of page two. It shows a resistor attached to the emitter leg, which I presume is to limit the current through the device. But trying to interpret the info in the table labeled "Electrical and optical characteristics" is leaving me at a total loss. I don't understand what the value and condition column.
    I'm looking to apply +5v at the collector. Am I correct at interpreting max current at 20ma? So using ohms law, my load resistor should be somewhere above 250ohms, right? Am I the only one who thinks that datasheet totally sucks?
    edited 2009-02-26 12:31
    Madcows,
    · The load resistor simply converts the varying current into a varying voltage that you can detect.
    · The Rise/Fall time table shows a load resistor of 100 ohms. And the Responce time chart shows that the load can be up to 10K.
    · You will probably have to experiment with different values to get the voltage levels you want out (this will depend you the amount of current you put through the LED).
    · The datasheet looks pretty standard to me. They never give you want you "really" want to know.
    P.S. Yes, you should have started a new thread...No biggie...
    Bean.
  • David BaylissDavid Bayliss Posts: 58
    edited 2009-02-26 14:01
    I don't know how important performance is; but for this particular case there is a slightly faster solution (single word instructions/no jumps or skips) if you don't mind trashing w:
    · mov· w, >>encBits
    ··xor · w, encBits
    · and· w,#1
    · add· enc_a_count,w
    · dec· enc_a_count
    David
    JonnyMac said...
    Encoder:
      CLR   testBits
    :encAcountSub
      DEC   Enc_A_count
      SKIP
    :encAcountAdd
      INC   Enc_A_count
    :End_A1_cngState
      RET
    edited 2009-02-26 14:51
    David,
    NICE... Elegant solution.. Only 6 instructions.
    Bean.
    edited 2009-02-27 00:10
    David Bayliss said...
    mov w, >>encBits
    xor w, encBits
    and w,#1
    add enc_a_count,w
    add enc_a_count,w
    dec enc_a_count
    David
    Wow! It took me a second to try to figure out why you were adding w twice, then performing a subtraction. Finally, zoot's version makes sense to me too! I don't know how some of your brains figure this stuff out! This certainly helped expand my mind on sx assembly, and logic.
    Mark S
    edited 2009-02-27 01:15
    Two decades as a compiler writer does odd things to your brain; I dream about this sort of stuff freaked.gif
    Actually, I missed a trick too ... now 5 words
    ·mov w,<<encbits
    ·xor w,encbits
    ·and w,#2
    ·add enc_a_count,w
    ·dec enc_a_count
    Same idea as before but accumulate the result in bit 1; allows the double add to be done in one instruction ...
    David
    madcows said...
    mov w, >>encBits
    xor w, encBits
    and w,#1
    add enc_a_count,w
    add enc_a_count,w
    dec enc_a_count
    David
    Mark S
    Thanks Bean....
    Ok.. does this sound right to you?:
    IL (14ma) is the current that will be sunk through RL (and whatever the next circuit sinks), and IF (20ma) is the total amount of current the detector circuit uses.
    Mark
