Plastic Enclosures Specifically
While I posted in a previous thread related to metal enclosures - which quickly deviated into cutting methods .. I decided to post a specific thread to suggested Plastic enclosure..
On the topic of enclosures - I work closely with a high volume plastics manufacturer .. I had played with and discussed with the customer - the idea of a plastic protoboard enclosure (2mm wall thickness) with pcb standoffs & screws,cover, switch slot and power led 'light pipe'- with 'knock out' (thin walled section easily trimmed out) sections for all the standard accessory kit items .. KB,Mouse and VGA as well as extra 'Knock out' sections throughout the enclosure to facilitate customisations ... If there was enough interest in these (by enough I mean enough to convince me to foot the tooling fees) I would certainly do it.
Also if anyone has suggestions on how a plastic protoboard enclosure should look .. then by all means post them here. The idea would be to have a quality sub $10 protoboard enclosure.
John Twomey
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
John Twomey
You could include the rich coating of dust at no extra cost.
Hmmm?
· -- Carl, nn5i@arrl.net
SRLM,
Again: www.lansing-enclosures.com.
www.polycase.com/
~~ dRu ~~
@Carl Hayes - Yip I am fully aware of tooling costs hence this attempt to guage interest and if interest - ideas to incorporate into the design - better to get it right first time (or a majority verdict) rather than have to redo it later. I am not convinced that there is enough interest for me to take the chance though ..
John Twomey
I think just about everyone will be interested... the only issue will be final cost. If you keep it cheap enough, guys will order by the dozen.
Rich
John Twomey
It could be neat to have a forum designed box, we just need someone with a little experience in this area to help do the modeling.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
Hasco back plates and quality steel rule here .. that experience (as suggested by you) was tried in Europe but failed ... it has been tried and tested .. in terms of tool building and repair .. the initial savings while substantial are negated (to say the least) by the resultant failures and associated cost of repair and rebuilding of the same tool with quality manufacturers.
John Twomey
Post Edited (QuattroRS4) : 2/26/2009 3:06:28 AM GMT
www.tdswieter.com
Your employer saw the light ! As you are more than well aware so - it's not just about cost! You seem to be aware of the varying opinions wrt China as a manufacturer. The experience I outlined was the same for many in that industry ... for them it was an expensive and time consuming disaster .. I do recognise that many have had good experiences. There are many other issues that need to be addressed e.g adhering to copyright and patent legalities .. but hey, lets not get bogged down ..
John
John Twomey
