Stamp LED Control & Electronics Books
MysticalMatt517
This is probably a pretty simple question, but I'm a raw newbie to the world of electronics and stamps.
I just read through the PDF of the "What's a Microcontroller" book to get an idea of how the stamps work. I see that you can control an LED using a resistor and having the stamp control the power flow.
It seems to me that the number of LED's you can control is limited by the outputs available on the stamp. I'd like to control 50 - 100 LED's... Not individually of course. I'd be fine to wire them in series so that they all turn on / off.
(Ideally it would be like a string of Christmas lights hooked to one stamp output)
The first problem that comes to mind is power. I'm thinking there's probably not of enough amperage to make this work. Is it possible to hook the LED's to a seperate power source and still have the stamp control a switch?
Finally, can anyone reccomend a *really good* beginner book on building electronic circuits? I'd love to learn, but most of the stuff I've found online is either really shallow or over my head...
For beginer books, nothing beats the Parallax Stamps in Class series (available for download free). Take a look here for more suggestions:
http://forums.parallax.com/showthread.php?p=741483
The stamps in class books are available as PDF's? Awesome. It looks like there's a lot of good info in the thread you linked to. At least I have a starting point for my project now.
Interesting chip! I did some searches, but the cheapest that I found was $10.80 from digikey. Do you know of any sources that sell the chip for less? I'd like to give it a try.
