Spy Gear - Spy Video Car - Controlled by Propeller using 4066 Quad Analog Switch
I wish to control a "Spy Gear - Spy Video Car" with the Propeller.
In order to electrically protect the Propeller, i·use a 4066 Quad Analog Switch (Motorola MC14066B). (See attached file for partial shematics)
The HighLand Electronics Co. "RX2" Chip and 4066 are powered by the·SpyVideoCar internal 3 volts regulator.
The Propeller will have it's own 5 volts regulated power supply (7805A).
The Propeller Pin 12 will connect to the 4066 Pin Control 2 with a 10K resistor using an RJ12 phone connector.
My problem is to figure out :
1) How to keep the 4066 Pin Control·2 to ground when the propeller is not connected ?
2) How to be sure the Propeller is well protected, do i need diode or else· ?
3) Since i have 3 volts and 3.3 volts circuit connecting together, do i have to do extra precaution ?
4)·The car·emit 2.4 GHz video signal inches from my little dautherboard and Proppeller how to·RF shield (do i need one)·?
Bruno
Bruno
1.) use a Pull-Down-resistor
2.) well protected against what ? The propeller is a 3.3V-device. Why do you want to connect the prop-chip to 5V ?
if the 4066 is supplied by 3V this will be enough for the propchip too.
3.) The Propchip works properly between 2.7V and 3,3V so it will work well at 3.0V
4.) depends on what you want to do. For low-frequency digital signals you need much less RF-shielding than for using two prop-pins
as a sigma-delta adc at 12 bit resolution
best regards
Stefan
This is especially true if the 4066 is using a supply higher than 3.3V.
In your case I don't see a problem since everything seems to have a 3V supply.
It can record video and audio up to 3.2 hours.
This is what I used: spy gear camera
I had fun with it and since the camera is also a webcam, I can see the video live on my computer
I just clipped on the front bumper on my RC car.[noparse][[/noparse]url]
Post Edited (freddyr) : 7/28/2010 1:54:58 AM GMT
