Easier Way to read certain bit of a byte or long? — Parallax Forums
SuperCricketSuperCricket Posts: 17
edited 2009-02-25 08:15 in Propeller 1
I've been trying to keep variable usage to a minimum for a program. I wanted to have on byte and flip each of the 8 bits depending on which of the 8 events is happening or not, rather than have 8 variables declared or an array.
How can I access a certain bit of the byte?
So far the hack job method I came up with is ANDing the variable depending on which bit I want to read and then shifting it over to see if its a one. Example:
To check if the 3rd from left bit is a 1
10101100
00100000 AND
00100000
Then shift right 5 places, and check to see if variable now equals 1.
=00000001
And to flip a desired bit I would have to XOR it back.
01001100
00100000 XOR
01101100
Above flips only the 3rd bit to a 1.
This is pretty rediculous and the resulting code to handle all of this probably uses more memory than just delaring 8 one-byte variables.
Any ideas?
Post Edited (SuperCricket) : 2/24/2009 1:09:30 AM GMT
    edited 2009-02-24 01:16
    The only way in Spin to manipulate individual bit is what you've already found, the bit logical operations. OR (|) will set bits, XOR (^) will toggle bits, and AND (&) can be used to turn off bits. If you have a mask with one bit set, you can set a bit in a variable X with X |= mask. You can toggle the bit with X ^= mask. Turning off the bit requires the complement of the mask as in X &= !mask. For single bits when you know the bit number, you can use |< bit# to generate a mask with only that bit set.
    For testing bits, you can make use of the fact that Boolean expressions are false if they're zero and true if they're non-zero so you can have IF X & mask. This will test for the masked bits in X and the IF will succeed if and of the masked bits are non-zero.
  • AribaAriba Posts: 2,697
    edited 2009-02-24 01:31
    Spin can manipulate and access single Bits of the special function registers (par, ina, outa ...).
    You can use DIRB and OUTB as Bit addressable registers on the current Prop, because this registers are implemented as RAM and not connected to a Port. This gives you 2*32 bits.
    If you not use the counters then also PHSx and FRQx can be used.
    To write a Bit:
    DIRB[noparse][[/noparse]bit] := 1
    To read/check a Bit:
    value := DIRB[noparse][[/noparse]bit]
    if DIRB[noparse][[/noparse]bit] == 1
    Andy
    edited 2009-02-24 01:36
    Clever idea Ariba! Of course, there should some warning at the top of the code of this use if it is a driver type object so that future users won't have problems when the Propeller comes out that uses the port B for real I/O pins.
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
    www.tdswieter.com
  • Bill DrummondBill Drummond Posts: 54
    edited 2009-02-24 08:55
    Why not skip the shift and test for zero?
    edited 2009-02-25 05:06
    SuperCricket,
    To elaborate on what Mike Green has said...
    variable &= !|<Bit·········· '<-- To Turn Off a Bit
    variable·|= |<Bit············ '<-- To Turn On a Bit···
    variable·^= |<Bit············· '<-- To Toggle a Bit
    BitValue := (variable & |<Bit)>>Bit··· '<-- To Read a Bit
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 2/25/2009 5:31:37 AM GMT
  • SuperCricketSuperCricket Posts: 17
    Ah thank you Beau and everyone else for the help!
