Doubts on CTRA — Parallax Forums
Doubts on CTRA
hal2000hal2000 Posts: 66
edited 2009-02-23 20:53 in Propeller 1
Hello all
I have a doubt on CTRA
I would like to generate a 5kHz signal on pin 20 and simultaneously
counting the pulses that result in a period of time.
Is it possible to use as CTRA oscillator, and PHSA to count the cycles?
Described in the manual, but I do not have enough English to understand
using CTRA
Thank you.
Did the curiosity kill the cat?
  • hal2000hal2000 Posts: 66
    edited 2009-02-23 11:18
    Watch this Object
    http://obex.parallax.com/objects/52/
    edited 2009-02-23 14:00
    Maybe CTRA is% 01011
    Is this cycle oscillator and counter with the same CTRA?
    Pin := 5
    DirA[noparse][[/noparse]Pin] := In
    CTRA := 0
    CTRA := (%01011 << 26 ) | (%001 << 23) | (0 << 9) | (Pin)
  • AribaAriba Posts: 2,697
    edited 2009-02-23 15:51
    If counter A produces a frequency, phsa is already in use, together with frqa (frqa is added to phsa every cycle, and bit31 of phsa is the output frequency). So you can't use the same counter to count pulses. This would need a totally different counter mode anyway.
    Andy
    OK
    CTRA used also oscillator
    CTRB a count
    Thanks!
