NEWB Heat sink question
Hi All
ME by college, so here is a stupid electrical question for ya.
So i have a row of 4, 8 amp triacs.
I want to add a heat sink.
Are the tabs of metal on the back of the triacs (heat sink with the hole in it) electronical seperated from the ciruit?
I ask because i intend to use 1 heat sink for all the triacs together.
Basicly mark up 1 peice of metal and use small screws thru all 4 holes to hold the metal to all 4 heat sinks.
Will this be ok?
Lucas
Will this be ok?
Lucas
Sometimes they are, sometimes they aren't. Get a multimeter and check if there is a HUGE resistance between each lead of the triac, and the tab. If there is infinite(or close to it), then the tab is probably isolated.
