Downloading stored data from an SD card with out removing the card.
Hello
I am looking for any ideas on how to extract data from an sd card with our having to remove it. I am storing rpm data from a shaft on an SD card.· The propeller and the sd card are inside a water tight enclosure and its impractical to open it everytime we need to see the data stored on the SD.· We are considering buying a underwater connector to make data extraction easier any objects out there to do this?
fsrw.popen("shaftdat", "r") [b]repeat[/b] [b]until[/b] (theByte := fsrw.pgetc) == -1 serial.tx(theByte)This will dump the entire contents of the file over the serial line. Is that what you need?
Post Edited (Jay Kickliter) : 2/22/2009 3:29:05 PM GMT
You won't find any existing objects to do this for you since the format of the information and the structure of the underlying program is so variable. I have seen partial XMODEM and KERMIT implementations in Spin, but they would require some work on your part.
Here's a link to some XMODEM code: http://forums.parallax.com/showthread.php?p=595861. It's for going the other way (from PC to Prop)
Maybe some others can chime in with links to other XModem, YModem, or Kermit implementations in Spin posted in forum threads.
in PropCOMM
Ray wrote a program to Ymodem application for uploading/downloading,etc to a Prop
from a serial terminal. It is here
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
