The compass object itself doesn't use any display. It just gets the data from the compass. The demo program supplied with the compass object is what uses the display. You can write your own program following the example given and use one of the serial drivers instead of the display driver. The HM55B object in the Object Exchange uses a TV display anyway, not a VGA display. Have you looked at it?
more indepth look at it. Thanks for the tip.
Martin
