Linear Actuator to BS2
I have a linear actuator, from a company called thomson apparently, and I can't find any documentation.· I know its 12V DC and maybe 1-2 amps, but I don't know what type of connection it requires (see picture).· Also, any suggestion on a good driver for use·with the BS2?·
They are actuated by a worm gear, and are quite powerful (we got one to lift the front of a car).
However, from my recollection, they were were very heavy on current (about 12A)
They have a permanent magnet motor, so reversing the polarity to the leads is the only way to·reverse the motor. As remmi870 suggested, you could use an H Bridge, or four discrete mosfets maybe.
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
