Pseudo Random Bit Pattern generation ideas — Parallax Forums
Beau SchwabeBeau Schwabe Posts: 6,572
edited 2009-02-25 10:04 in Propeller 1
Suppose I have 9-Bits, and within the 9-Bits I want a specific number of random bits that would range from 0 to 9.
Anyone have a cleaver code idea for this?
Example1:
I want 5 random bits "ON" within the 9-Bits...
A few possible results:
%101010101
%110010101
%101100101
%011100110
Example2:
I want 3 random bits "ON" within the 9-Bits...
%000010101
%110000001
%001000101
%010000110
I could·do this with brute force, but I was looking for a small compact elegant solution, I don't care if it's in Spin or Assembly and pseudo random is ok.
Beau Schwabe
IC Layout Engineer
  • whickerwhicker Posts: 749
    edited 2009-02-21 20:59
    Beau, the only thing I can think of is to just shuffle around bits randomly.
    in the case of 5 one bits, start with %0 0001 1111
    start at the first bit, swap with a random bit location (0 to 8) including itself.
    start at the second bit, swap with a random bit.
    etc.
    not elegant but it would do the job.
    Are you trying to do something related to dithering? Where error could be accumulated over more than one 9-bit chunk?
  • jazzedjazzed Posts: 11,803
    edited 2009-02-21 21:12
    Wikipedia mentions the John von Neumann "middle-square method" which I've used on several projects for generating test data. It is primitive but light weight and creates a fair distribution.
    --Steve
    edited 2009-02-21 21:33
    whicker,
    Interesting... I hadn't thought of it from that end.. starting from the number of bits I wanted "ON' ... I might try that and see which one is faster... I imagine your method would be, because there is no chance of turning on a bit that is already lit up.
    Here is my brute force method...
    PUB GetRandomDigit(Digit)    ' Digit ranges from 0 to 9
        OldPattern := Pattern
        Pattern := 0
        if Digit <> 0
           if Digit <> 9
              repeat
                Pattern := 0
                repeat n from 1 to Digit
                  ?Seed
                  Temp := Seed & $FF
                  Temp := (9 * Temp)/$FF
                  Temp := |<Temp
                  If Pattern & Temp == Temp
                     n := n-1
                  Pattern := Pattern | Temp
                If Pattern <> OldPattern
                   quit
           else
              Pattern := %111111111
        Return Pattern
    Beau Schwabe
    IC Layout Engineer
  • Carl HayesCarl Hayes Posts: 841
    edited 2009-02-21 21:52
    I'll describe a possible method in a sort of pseudo-Spin. You'll see what I mean.
    Result = %000000000
    Bitcounter = 0
    Repeat
    ..N := (<random number> // 9)
    ..If Nth bit of Result not yet set
    ....Set Nth bit
    ....Bitcounter := Bitcounter + 1
    ....If Bitcounter == <desired number>
    ......quit
    Rats, it threw away·my indents.· Putting them back with periods.
    · -- Carl, nn5i@arrl.net
    Post Edited (Carl Hayes) : 2/21/2009 9:59:27 PM GMT
  • heaterheater Posts: 3,370
    edited 2009-02-21 21:53
    If you feel the need for speed put all the possible patterns in a look up table and index it with the random number.
    edited 2009-02-21 22:24
    Thinking about this further, I guess as a further optimization, if there are more ones than zeroes, like 8 of 9, or %0 1111 1111,
    you might as well go %1 1111 1110 and then just shuffle that single zero.
    so for zero and nine bits set, the answer is known already.
    for 1 to 4 bits set, at most 4 shuffles of 1's are needed.
    for 5 to 8 bits set, at most 4 shuffles of 0's are needed.
    %000000001
    %000000011
    %000000111
    %000001111
    %111110000
    %111111000
    %111111100
    %111111110
    The reason I suggest it this way is that the time of completion is known. If you wanted consistent time completion, then 9 swaps would take place regardless of the distribution of 1's to 0's.
    edited 2009-02-21 23:11
    Beau,
    Here's a program that uses the Fisher-Yates shuffle to randomly permute the n least-significant bits of any long. It will do what you want.
    [b]CON[/b]
       [b]_clkmode[/b]       = [b]xtal1[/b] + [b]pll16x[/b]
       [b]_xinfreq[/b]       = 5_000_000
       NBITS          = 9
    [b]OBJ[/b]
      tv    : "tv_wtext"
    [b]PUB[/b] Main | permutation
      tv.start(12)
      permutation := %1111
      [b]repeat[/b]
        permutation := permute(permutation, NBITS)
        tv.bin(permutation, NBITS)
        tv.out(13)
        [b]waitcnt[/b]([b]cnt[/b] + clkfreq)
    [b]PUB[/b] permute(p, n) | j, k
      'Randomly permute the n least significant bits of p.
      [b]repeat[/b] [b]while[/b] (--n)
        k := |<(||?rand // n)
        j := |<n
        p := (p & !j & !k) | (p & k <> 0) & j | (p & j <> 0) & k
      [b]return[/b] p
    [b]DAT[/b]
     rand          [b]long[/b]      $12345678
    edited 2009-02-21 23:17
    Phil Pilgrim (PhiPi),
    Thanks, I will try tried that out
    Edit
    Perfect!
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 2/21/2009 11:26:38 PM GMT
    edited 2009-02-21 23:29
    So you can use the '?' operator [noparse]:)[/noparse] Ok [noparse]:)[/noparse]
    --Steve
  • Michael O'BrienMichael O'Brien Posts: 55
    edited 2009-02-21 23:41
    Beau,
    I don't know if this helps but the center row of bits on Stephen Wolfram's 1-dimensional binary cellular automaton when computing rule 30 is random and ideally fully non-deterministic. The Wolfram CA is based on John von Neumann 29 state and E.F. Codd's 8 state CA's. You would be limited by the size of the array required for simulation and/or if it was toroidal.
    Computing the next state of the cell is like moving a 74HC151/251 8-1 line multiplexer across the bit array where - 3 cells at a time form the address on a lookup of the transition rule (30 = 0000:1110)
    see
    http://mathworld.wolfram.com/Rule30.html
    thank you
    /michael
    edited 2009-02-22 04:13
    Beau, if it can't use ? in pasm to generate the random number, maybe it could be an lfsr would do. Executed several times in a row until it again has the correct number of bits. Something like the following. It could be forced to execute at least 9 times to clear out existing bits.
    {new 5 of 9 bit pattern snippet}
    lfsr5of9       CALL #lfsr1    ' repeatedly calls the lfsr until there are again 5 ones
                      TJNZ sum5bits, #lfsr5of9    ' variable sum5bits=0 when there are 5 of 9 ones
    lfsr5of9_ret  RET
    lfsr1            XOR x, mask            wc,nr     ' mask for lfsr, carry=1 iff parity odd
        IF_C        ADDS sum5bits, #1   ' will increase number of 1s on odd parity
                       AND x, #$100        wz, nr  ' test bit 9
         IF_NZ     SUBS sum5bits, #1   ' will decrease number of 1s if bit 9 is not zero
                       SHL x, #1         wc      ' okay, shift
         IF_C       OR x,#1       ' and shift in the carry from the XOR
    lfsr1_ret      RET
    sum5bits  long  0             ' keeping this at 0 maintains 5 of 9 pattern
    x        long  101010101     ' start with a 5 of 9 pattern
    mask   long   $802000003    ' for lfsr, a good value for a 32 bit word according to xilinx app note 52
    Tracy Allen
    www.emesystems.com
    edited 2009-02-22 05:58
    Here's a program I used to compare Spin and assembly versions of the Fisher-Yates shuffle:
    [b]CON[/b]
       NBITS          = 9
    [b]OBJ[/b]
      tv    : "tv_wtext"
    [b]PUB[/b] start | permutation, time0, nperline, i
      paddr := @pp
      naddr := @nn
      [b]cognew[/b](@asm_permute, 0)
      tv.start(12)
      nperline := 40 / (NBITS + 1)
      time0 := [b]cnt[/b]
      i := nperline
      [b]repeat[/b] 1000
        permutation := apermute(permutation, NBITS)
    {  'Uncomment to display results.
        [b]if[/b] (--i)
          tv.out(" ")
        [b]else[/b]
          tv.out(13)
          i := nperline
      tv.dec ([b]cnt[/b] - time0)
    [b]PUB[/b] apermute(p, n)
      'Randomly permute the n least significant bits of p in assembly.
      pp := p
      nn := n
      [b]repeat[/b] [b]while[/b] nn
      [b]return[/b] pp
    [b]PUB[/b] spermute(p, n) | j, k
      'Randomly permute the n least significant bits of p in Spin.
        j := |<n
      [b]return[/b] p
    [b]DAT[/b]
    asm_permute   [b]rdlong[/b]    nn,naddr [b]wz[/b]             'Is there anything to do?
            [b]if_z[/b]  [b]jmp[/b]       #asm_permute            '  No:  Try again.
                  [b]rdlong[/b]    pp,paddr                '  Yes: Get the bits to permute.
    :loop         [b]sub[/b]       nn,#1 [b]wz[/b]                '--nn > 0?
            [b]if_z[/b]  [b]jmp[/b]       #:done                  '  No:  Done.
                  [b]xor[/b]       rand,taps [b]wc[/b]            'Next random number,
                  [b]rcl[/b]       rand,#1                 '  via LFSR.
                  [b]mov[/b]       acc,rand                'Compute random mod nn
                  [b]mov[/b]       accx,nn
                  [b]call[/b]      #modulo
                  [b]mov[/b]       kk,#1                   'Get second bit into position for swap.
                  [b]shl[/b]       kk,mod
                  [b]mov[/b]       jj,#1                   'Get first bit into position for swap.
                  [b]shl[/b]       jj,nn
                  [b]test[/b]      pp,jj [b]wz[/b]                'nz is first bit in pp.
                  [b]test[/b]      pp,kk [b]wc[/b]                'c is second bit in pp.
                  [b]muxc[/b]      pp,jj                   'Swap bits.
                  [b]muxnz[/b]     pp,kk
                  [b]jmp[/b]       #:loop                  'Back for all n-1 iterations.
    :done         [b]wrlong[/b]    pp,paddr                'Write result.
                  [b]wrlong[/b]    nn,naddr                'Write zero to say we're done.
                  [b]jmp[/b]       #asm_permute            'Back to wait for more.
    modulo        [b]mov[/b]       mod,#0                  'mod := acc // accx.
                  [b]mov[/b]       ctr,#32                 '(Wouldn't really need all 32 bits; could be 16.)
    :divlp        [b]shl[/b]       acc,#1 [b]wc[/b]
                  [b]rcl[/b]       mod,#1
                  [b]cmpsub[/b]    mod,accx [b]wc[/b]
                  [b]djnz[/b]      ctr,#:divlp
    modulo_ret    [b]ret[/b]
    rand          [b]long[/b]      $12345678               'Random number seed. Anything but 0 is okay.
    taps          [b]long[/b]      $8020_0003              'Taps for LFSR. Thanks, Tracy!
    naddr         [b]long[/b]      0-0                     'Address of nn.
    paddr         [b]long[/b]      0-0                     'Address of pp.
    nn            [b]long[/b]      0-0                     'Hub (and cog) container for nn.
    pp            [b]long[/b]      0-0                     'Hub (and cog) container for pp.
    acc           [b]res[/b]       1
    accx          [b]res[/b]       1
    mod           [b]res[/b]       1
    jj            [b]res[/b]       1
    kk            [b]res[/b]       1
    ctr           [b]res[/b]       1
    After subtracting the loop overhead, I got the following results per call for the permute routines:
    ····spermute: 811 µs
    ····apermute: 92 µs
    By reducing the number of bits in the modulo operation to 16 from 32:
    ····apermute: 67 µs
  • virtuPICvirtuPIC Posts: 193
    edited 2009-02-22 14:58
    A completely different approach. You want pseudo randomly set k bits out of a total of n = 9. How many (p) such patterns are possible? Here we get the binomial coefficient: p = n! / ((n - k!) * k!). So you get at most 126 patterns for k = 4 or k = 5.
    What about generating a pseudo random number and table lookup?
    Airspace V - international hangar flying!
    www.airspace-v.com/ggadgets for tools & toys
    edited 2009-02-22 17:22
    virtuPIC,
    For numbers in this size range (9, 4), that's certainly a solid approach. Now, since you brought it up, can you:
    1. write a program that will generate the table?
    2. do it without sifting through all 512 binaries and picking just the ones with four bits set?
    edited 2009-02-22 19:46
    Here is a slightly modified version of Phil's original suggestion.· This version·will·trap any duplicate sequences...· Thanks Phil
    PUB RandomizeCharacter(OldPattern,Character)|k,j,p,n     ' Character ranges from 0 to 9
        repeat
          n := 9
          p := |<Character-1
          repeat while (--n)
            k := |<(||?Seed // n)
            j := |<n
          if p<>OldPattern or p==|<9-1
             quit
        return p
    DAT
    Seed                    long      $12345678     '<--- In the final application, this will be seeded with a Real Time Clock.
    Beau Schwabe
    IC Layout Engineer
    edited 2009-02-23 07:16
    Phil: Yes, I can. But not in the next few hours. Will do it tonight (European time).
    edited 2009-02-23 21:23
    Hey Phil, here we go:
    'Generates pseudo random values with exactly 4 bits of the lowest nine bits set, all other bits cleared.
    '(C) 2009 virtuPIC@gmail.com
    'Seeds PRNG and initializes table.
    PUB init(seed) | i, i0, i1, i2, i3
      rnd := seed
      i := 0
      i0 := 1
      repeat until i0 => 512
        i1 := i0 << 1
        repeat until i1 => 512
          i2 := i1 << 1
          repeat until i2 => 512
            i3 := i2 << 1
            repeat until i3 => 512
              if i => 126
                abort 'catch internal error (should not be reached)
              tab[noparse][[/noparse]i++] := i0 | i1 | i2 | i3
              i3 <<= 1
            i2 <<= 1
          i1 <<= 1
        i0 <<= 1
      if i <> 126
    'Returns pseudo random value
    'N.B.: values are not perfectly equally distributed! However, mismatch is smaller than 1 PPM.
    PUB fourofnine
      return tab[noparse][[/noparse]||?rnd // 126]
    VAR
      long rnd
      word tab[noparse][[/noparse]126]
    You can replace the dynamic table init by a table constant generated by an external program like this one:
    // Generates table for alternative version of forofnine.spin
    // (C) 2009 virtuPIC@gmail.com
    #include <stdlib.h>
    #include <stdio.h>
    int main() {
      int i, i0, i1, i2, i3;
      i = 0;
      i0 = 1;
      while (i0 < 512) {
        i1 = i0 << 1;
        while (i1 < 512) {
          i2 = i1 << 1;
          while (i2 < 512) {
            i3 = i2 << 1;
            while (i3 < 512) {
              if (i >= 126) {
            printf("i too large: %d", i);
            exit(1);
          i++;
          printf("$%x", i0 | i1 | i2 | i3);
          if (i < 126) {
            printf(",");
          printf("\n");
          i3 <<= 1;
        i2 <<= 1;
          i1 <<= 1;
        i0 <<= 1;
      if (i != 126) {
      printf("i wrong on exit: %d\n", i);
        exit(1);
      return 0;
    As usual, optimality depends on application. Calculating the table on the prop at start up needs some time. I haven't looked at the size. Cannot tell which version consumes more memory.
    And a warning at the end: I have only statically tested the SPIN code. Be prepared for bugs.
    edited 2009-02-23 22:03
    virtuPIC,
    Nicely done!
    edited 2009-02-24 01:37
    virtuPIC,
    Thanks for posting your code.... I think though since I don't really need the speed at all for my application, and since I already have it implemented in code I will use Phils' permutation method.· With the few Checks I have added in place for a 0 or 9 it only uses 20 longs of program space.
    Beau Schwabe
    IC Layout Engineer
  • Ken PetersonKen Peterson Posts: 806
    edited 2009-02-24 01:38
    pub set_random_bits(size, num) | large, temp
      result~
      large := (num > (size>>1))
      if large
        num := size-num
      while(num)
        temp := result | (|<(cnt? // size))
        if temp <> result
          result := temp
          num--
      if large
        result ^= |<size - 1
    Not very deterministic, but the code isn't very long.
    What it does is set less than half the bits. If your number of bits to be set is more than half the size, it sets the number of bits that should be zero and then inverts the result. This way you always have a >=50/50 chance of the random bit not having already been set.
    For execution speed, the worst case scenario will be when the number of bits to be set is equal to half the total number of bits.
    ·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
    - Bjarne Stroustrup
    Post Edited (Ken Peterson) : 2/24/2009 2:09:23 AM GMT
    edited 2009-02-24 09:30
    Okay. Since this thread doesn't come to an end what about this one:
    code deleted for two reasons:
    • It was wrong. Could have caused problems if used.
    We could also replace the operations 'x // c' by 'x ** (2^32 ) / c' to accelerate. Well, 'x // 8' can even be done be 'x & 0x3'...
    Post Edited (virtuPIC) : 2/25/2009 9:43:12 AM GMT
    edited 2009-02-24 14:13
    Oops! Good that nobody else has talked about probabilities. My last recent program does not produce all patterns at the same probability! However, if you replace the PRNG-call with a counter you can use it as a generator for the table in my other program, too...
    Maybe I think a little about the program with mixed probs and fix them. Yeah, I know. Nobody will use it anyway. But it's demanding. And it's fun.
    edited 2009-02-24 18:34
    App note 52 from Xilinx has a table with taps for LFSRs from 3 to 168 bits long, vetted for period length and presumably other statistical properties. Nevertheless, single iterations of LFSRs are not great for bytes etc, due to the steady march of bits in one direction. That will be irrelevant in Beau's application, I think, and with the additional permutations or lookups.
    But that brings me to my math question. The Spin operator ? is, according to the manual, an LFSR that can be used forward ?X or in reverse X? Neat! Retrace steps. But how does an LFSR do that? The manual states.
    The Propeller chip’s Random output is reversible; in fact, specifically it is a 32-bit
    maximum-length, four-tap LFSR (Linear Feedback Shift Register) with taps in both the LSB
    (Least Significant Bit, rightmost bit) and the MSB (Most Significant Bit, leftmost bit)
    allowing for bi-directional operation.
    However, it is not as simple as shifting right with the same set of taps. For example, taps=$802000003 is a four tap mask with taps in both the lsb and msb, however, it does not take long to come up with a counterexample, where the left shift is not reversible with a right shift using the same taps. Short of iterating the forward map 2^32-2 times, is there a trick to make it reversible? Looking shallowly on line, it looks like there exists a complementary set of taps, that mathematically can generate the reverse sequence. But the circuit to do it is not trivial, example here. Hmmm...to echo the Joker, how does he do that?
    Tracy Allen
    www.emesystems.com
    edited 2009-02-24 19:29
    Tracy,
    The key element is that the bit that gets shifted out is involved in the XOR process. That way, the XOR product that gets shifted into the other end can be used to reconstruct this bit from the other taps. In this case, the taps for the reverse case are just the same taps as for the forward case, rotated by one position in the direction of the original shift. (You don't really have to have both the MSB and LSB set in the original mask — just the one corresponding to the bit that gets shifted out.) For example, if your original mask is %11010000_00000001, and you're shifting right, the new mask for shifting left will be %11101000_00000000. This is enough to reconstruct the bit that got shifted out in the forward direction and to shift it back into the other end.
  • Fred HawkinsFred Hawkins Posts: 997
    edited 2009-02-25 03:01
    Tracy, the attraction of lfsr is that it will give every number of a given set of integers in a pseudorandom order without duplication before starting over. So an array of nine bit numbers, randomly arranged, could simulate a lfsr.
    It occurs to me now that you could just keep a set of constants, one for each bit. Just add (or not) them to build your new instance.
    binary:
    0_0000_0001
    0_0000_0010
    1_0000_0000
    Arrange these randomly, maybe following the 4 bit lfsr's order which has nice properties.
    then you need a set of eight starting instances of one set bit through 8 set bits.
    To get an new instance of any of these, run a nine step loop that shifts off a bit from the old instance, and if it's set, add the nth binary to your new instance. If you keep track of the number of adds, you can even drop out of the loop when you have set the appropriate number of bits.
    My guess is that it's random enough. You could reshuffle the binary array every now and then if you're worried about that.
    Post Edited (Fred Hawkins) : 2/25/2009 3:09:29 AM GMT
    edited 2009-02-25 08:26
    Thanks Phil. I was way over-complicating! I see what you mean about the key. It helps to think about it as one step in each direction, and how to solve for the unknown bit. Let me see if I've got it...
    Say for these taps for the 32 bit lfsr
    $8020_0003 for shift left
    with the new lsb from
    x0 := x31 ^ x21 ^ x1 ^ x0
    with x31 being lost after the shift, but it can be recomputed from the new x0 along with the now shifted x1, x2 and x22.
    The taps for shift right would be
    $0040_0007
    with new msb from
    x31 := x22 ^ x2 ^ x1 ^ x0
    Tracy Allen
    www.emesystems.com
    edited 2009-02-25 10:00
    Regarding bidirectional LFSR, if I remember correctly an n bit LFSR implements a polynomial multiplication with the tap sequence interpreted as a polynomial modulo xn in GF(2). Each single step is such a modulo-multiplication. If you want to step back you have to divide by the tap sequence polynomial modulo xn. You won't loose information since the multiplication in GF(2) mod xn is a group operation and the tap sequence polynomial is primitive if you have maximum period taps. Yes, that's computer algebra. It's weird. It's complicated. I looked around on the net but couldn't find any comprehensive, complete explanation.
    If you look at en.wikipedia.org/wiki/LFSR you will find two possible implementations in hardware (Fibonacci and Galois) giving different sequences. Maybe we should try to rewire them that each clock to the SR gives backward change? Or simply look it up in the code of the SPIN interpreter?
    Well, my last posting was a little theoretical. But here I am again for the practical part. My last implementation was so embarrassing wong that I deleted the code in shame. But I have a new idea:
    ' alternative version of fourofnine.spin
    ' (C) 2009 virtuPIC@gmail.com
    ' differences:
    ' + k_of_9 instead of 4_of_9
    ' + less memory consumption
    ' - much slower
    ' Initializes
    PUB start
      ' Seed PRNG
      rnd = cnt | 1
    ' return value with k randomly selected bits out of the 9 LSBs
    PUB fourofnine(k) | idx, sel, pat
      pat := 0
      ' Initialize list of bit positions
      ' Could be accelerated by assigning longs instead of words
      repeat idx from 0 to 8
        pos[noparse][[/noparse]idx] := |< idx
      repeat idx from 0 to k - 1
        sel := ?rnd // 9 - idx
        pat |= |< pos[noparse][[/noparse]sel]
        pos[noparse][[/noparse]sel] := pos[noparse][[/noparse]9 - idx]
    VAR
      word pos[noparse][[/noparse]9]
      long rnd
    Again, the Propeller Tools swallows it, but I haven't run it so far.
