Stamp woes
I have been using the BS2 OEM module and a BS2e module in a home monitoring project. The code I wrote uses RCtime command to measure temperature changes. Both have worked fine. Until now. I don't know what I did but neither are working. I was getting a "EEPROM verify failure" on the BS2e module, now I am getting "No stamp found" for both.... I have checked the RS232 connection, the COM port, and PS and all looks as it should. I am obviously missing something.
My question is, what can I check (with my scope/or meter) that will confirm that either module has been zapped? For an example, I see a pulse train on pin 8 of the BS2 module.. any suggestions?
Do the 7805s run from the same power source?
Voltmeter verified?
Loopback Yes = cable connected.
What is irritating about this is that both worked fine. I can't see anything that I might have done to cause this...obviously I did something!
