-180 to 180 degree roll angle from memsic
Is it possible to get full tilt in one direction with a memsic sensor tilted 90 degrees?
And if possible, can I use the memsic propeller object in any way to do it?
Airspace V - international hangar flying!
www.airspace-v.com/ggadgets for tools & toys
Have seen this kind of sensing beeing done·with pendulum from goodrich,
they was filled up with oil so the acceleration should not make any big impact,
I`m trying to do the same·by only·letting the code travel one degree at a time...
i`m going to use in a underwater robot, so the movement is very slow...
