Trouble with the 2x16 LCD and Prop Chip
I just got this (http://www.parallax.com/Store/Accessories/Displays/tabid/159/CategoryID/34/List/0/Level/a/ProductID/52/Default.aspx?SortField=ProductName,ProductName) LCD today, and am trying to use it with a prop chip.
It requires 5v power, so it is on its own power source, and the test works on it (meaning setting both switches to off to show the Parallax info on the screen).
That said, set to 9600 baud and sending it data from pin 10 on the prop doesn't do anything to it...is it the 3.3v vs. 5v difference that is causing this? Can I even drive this screen from the prop chip?
Connect a Prop pin to the LCD data pin through a 1K resistor.
Code will look something like this
etc.
I feel like I am getting this whole electronics thing now...and knowing the answer to this may be a breakthrough moment for me [noparse]:)[/noparse]
Parallax Engineering
