clock speed and r/c circuit (RCTIME)
I wrote some code that runs perfectly on the Basic Stamp. Because SX chips are so much cheaper, I'm converting the code to SX/B. My code has some RCTIME functions that don't seem to be working on the SX28. Could it be the different clock speeds of the chips? Also, a side question, is there an easy (or not-so-easy) way to see debug statements using SX28?
Thanks for the help!
- RCTIME should work nearly the same as on the Stamp, but read the manual -- and check your resolution. Make sure you have an accurate clock source (either an external resonator or the SX-Key).
- there is no "debug" on the SX like there is on the Stamp. You can "WATCH" variables which lets you see their values on your PC while you are running a program. Read up on debugging -- there is a lot you can do, but it's not like the Stamp.
- you can program your SX to send ASCII serial data a la "DEBUG" on the Stamp. You would need level-shifter circuitry to convert the TTL serial data from the SX to RS-232 for your PC, but if you just need to see variable values (like the results of an RCTIME) then using the regular debug features would probably be simplest.
- can post your circuit and code? Otherwise it's just guesswork from this end.
So, here's the code... I'm attaching a picture of the SX proto board (ignore the red wires, they are my home-made Vin). I have two resisters in series coming from pin rb.7 totalling approximately 220-ohms, then a 0.1uF cap and 15k-ohm in parallel to ground.
' File...... test RC-Time Circuit 2009-04-25.sxb
' Purpose... test rc-time
' Author....
' E-mail....
' Started...
' Updated... 2009-
' Program Description
' Device Settings
DEVICE SX28, OSC4MHZ, TURBO, STACKX, OPTIONX
FREQ 4_000_000
' IO Pins
PhotoR PIN RB.7 ' RC-Time from photo-resistor
' Constants
' Variables
T VAR Word
INTERRUPT
ISR_Start:
' ISR code here
ISR_Exit:
RETURNINT ' {cycles}
PROGRAM Start
Pgm_ID:
DATA "SX/B Template", 0
' Subroutines / Jump Table
' Program Code
Start:
' initialization code here
Main:
' main code here
COUNTER = 0
high ra.0
do while counter < 100
HIGH PhotoR
pause 20
PULSIN PhotoR, 1, T
counter = counter + 1
loop
low ra.0
do
loop
GOTO Main
' Page 1 Code
'Page_1:
' ADDRESS $200
'P1_Start:
' GOTO P1_Start ' error if Pg0 overruns Pg1
' Page 2 Code
'Page_2:
' ADDRESS $400
'P2_Start:
' GOTO P2_Start ' error if Pg1 overruns Pg2
' Page 3 Code
'Page_3:
' ADDRESS $600
'P3_Start:
' GOTO P3_Start ' error if Pg3 overruns Pg4
Did you mean PULSIN ???
PULSIN does have different timing in SX/B than on the Basic Stamp.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
