Handheld Prop
Oldbitcollector (Jeff)
I'm working on a quick little hardware project now that I've got my shop back in order.
A hand-held Propeller toy. {pic attached}
(Sorry Nick, I tried to use a GG board for this, but I just couldn't work out the buttons.)
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
Post Edited (Oldbitcollector) : 2/19/2009 3:59:17 AM GMT
OBC
But you can't enter your contest - it has more than $1 of components - hahaha!!!
However, if you had used bits from an old mobile phone..... maybe grandma had one laying around
· Home of the MultiBladeProps (SixBladeProp)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
My cruising website is: ·www.bluemagic.biz
I've added a couple more shots to the top thread..
If you've never attempted to attach an SD adapter directly to the Protoboard they
work out quite nicely! Simply prep the holes with some solder. Push the pins
down into the solder, and run some lines in the adjacent holes. (bend for connection)
I was tickled that Vss worked out just perfectly... [noparse]:)[/noparse]
OBC
--Steve
Whit+
