Dancing fountain or Jumping frogs
I have built a fun project that shoots pulses of water around an indoor pond. These pulses "jump" from one spot to another. It is motion actuated so only runs when someone is there to see it.
This pond is in a dome/greenhouse Located in Perrysburg Ohio.
I use 12 solenoid valves connected to a water line.
These solenoid valves are 24 volt DC and are controlled by a Basic Stamp II via 5 volt relays.
I use 2N2222 transistors to drive the relays.
Because the environment is very humid I went with a plastic enclosure with a gasket and had only 3 through holes. One for the PIR sensor, one for power and the last was for the wiring to the solenoid valves.
You can see a video of the action here:
www.youtube.com/watch?v=IGGjWpk0qy8
The Pictures show the box with epoxied stand-offs to minimize through-holes, and then everything inside the enclosure and finnaly one of the solenoid valves I used.
Mike2545
This message sent to you on 100% recycled electrons.
Post Edited (Mike2545) : 2/20/2009 4:16:46 AM GMT
Mike2545
Very nice indeed. It’s nice to see projects there are out there for everyone to appreciate. Take care.
Parallax Engineering
BWIN ON DA POWAH WIFIN U!!!
(This means the Plutonium Isotope Nuclear Fission And Fusion Reactor Battery Pack you've been hiding inside your jacket!!!)
Why does it only work if the stream is continuous? You can turn the light on and off at the same time as the water, so no problem. You'd have to do some serious engineering to make it look good: you have to immerse the LEDs in the stream and you can't let them break up the flow of the water. Tough, but it should be possible. Maybe shoot the stream and have the LED on the bottom and just touching the water?
The video does not do it justice, it's better in person.
Mike2545
Great work!
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
I want to take my Christmas Light show controller and setup a water show, so I can make use of my hard work for more than only at Christmas. Where did you get the solenoids? They appear to be much smaller than the ones I have found so far.
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
I found the solenoids on e-bay. Lot of 36 for $80.00 (plus shipping) came out to around $3 per valve. If you look around you can find good values.
On a side note, I had to install a "shock absorber" in the water line. The rapid closing of the valves was having an effect on the pipes in the building that supplied water to the green house. Luckily I had an old expansion tank from a boiler that worked at quieting the water hammer.
I have one person wanting me to build a "dancing fountain" for their home [noparse]:)[/noparse]
Mike2545
I just might "borrow" your idea and do something similar for my outdoor pond! What did you use for your water pump?
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
1) Debris getting lodged in the solenoid
2) Turning the pump on and off may have undesired delay times
We need to add water to the pond on a weekly basis as is,so this does it in a fun way.
Mike2545
But otherwise it would be like having a water tower.
I found it easier to attach directly to the water line.
This is a picture of the greenhouse where the dancing fountain is located.
Mike2545
How bout something like this? The more laminar the flow, the better it catches the LED light located inside the nozzle
I'm looking into the more sophisticated software and hardware to use in our dancing fountains as in our website http://www.industronfountains.com
I'm learning a lot from these forums. Thanks for sharing your ideas!
Hey, what a small world. You and I have a e-mail conversation going on through Brilldea for this. I will respond to your specific questions in an e-mail, but I will provide some general thoughts here.
I think a controller could be made with an SX or Propeller (I prefer propeller). The Propeller can have sequences I/O for controlling the solenoid valves. Depending on how advance you want to be, the Propeller could also control the lighting in the nozzle (LED?). The controller could have an internet connection for getting data/schedules. It could also have a DMX-512A connection for controlling the sequence. Even one more, the Propeller Controller could have an SD card slot and preprogrammed shows/sequences could be included on the card and played back. There would be the initial controller design, but that shouldn't be too bad. Then it is making the electronics assembly and integrating it into your current control system. If you are using PLCs now, then perhaps a Propeller based controller would be cheaper - and customized to your applications.
Other fountains have used custom controllers or used items like Gilderfluke's or Alcron McBride's show controllers.
I have am passionate about theme parks, themed entertainment and all things in the effect world. I haven't had a chance to work on a real fountain, but I have been dreaming about it for a while. I drool every time I see a WET design.
We can talk more in our offline e-mails.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
