heart rate monitor Receiver
First let me say that I am very new to electronics. I have gone through most of the "what's a microcontroller?" text over the course of the past few weeks, but that is the extent of it.
I am trying to make a project using a heart rate monitor and receiver. The basic idea is that the position of a servo will be directly related to my heart rate. I have a transmitter strap which gives off a 5 MHz pulse with every heart beat it detects and I just bought this receiver circuit: http://www.sparkfun.com/commerce/product_info.php?products_id=8661
Honestly, I don't totally understand this thing. There are several options to attach it to a computer, and I think that for the basic stamp I want to use the logic-level physical interface. So there are four slots (I don't know the right jargon) Marked 5V, GND, RX-I/SDA, and TX-O/SCL
What I assume should happen is that I connect "5V" to the Vdd and GND to Vss, then can the RX-I and TX-O attach to any of the slots P0-P15? Does the basic stamp receive a "on/off" type signal from the receiver circuit?
I hope that these questions make sense. I'm not totally sure what I am dealing with and the manuals for the basic stamp and the Heart rate monitor interface are not helping.
Thankyou,
Blue
Thankyou,
Blue
Terry
- Stephen
Page 10 and following of the manual (on the Sparkfun site) tell you how to set up the jumpers to select serial or I2C:
"Without a jumper across OP0 the micro-controller communicates
using a serial interface through either the Logic-level connector or USB connector. With a jumper across OP0 the microcontroller
communicates using the I2C protocol."
Both are interfaces that you can use with Stamp modules. Serial is, as you suspected, probably the better way to go, which means you should leave the jumper off of OP0.
Yes, power the receiver with 5v and ground as you suggest. You'll need to use the same ground, at least, as the Stamp is using, and I suspect you can use 5v from the Vdd from your Stamp as well.
Once you do that, the Rx and Tx lines are used with SERIN and SEROUT on the Stamp to communicate. You'll need to set jumpers to set a Baud rate, per page 11 of the manual. Try 2400 first. You'll need to use the same settings with your SERIN/SEROUT commands on the Stamp, so 8N1 2400 would be 396 on the BS2 (see the PBasic manual sections on SERIN and SEROUT to pick the right codes, or just ask here again). The "Operations" part of the receiver's manual (p. 20ff) tells you about how to communicate with it. Try sending (SEROUT) "G3", and then receiving (SERIN) the next 5 bytes.
(no guarantees on the exact code - there's always some "tweaking" that has to happen to get these things to work right)
You should get two status bytes (see page 26 of the receiver's manual) and three heartrate numbers (see p. 21 of the manual). Page 23 of the manual lists the commands and the data that some of them return.
I don't know what you mean by "a on/off signal", but I think the answer to that question is "no". You're going to have to send out command bytes and then read in the responses.
Post Edited (sylvie369) : 2/19/2009 3:59:47 AM GMT
