Brushless motor enigma
im am looking for a brushless motor that i can play with, in other words, i have a ton of ideas, but no motors that i can use as i have no brushless motors. i need a motor that can do various thing that doesnt cost an arm and a leg and also looks elegent, because my friends and family doesnt understand the awesome stuff that a machine can do looks mean everything to them, i need a motor that can be used as a high speed rotary tool like a dremel that i can use by making a motor mount that is hand held and can be attached to something in case i want to build a cnc machine. the motor will also be used for spinning a tesla turbine, i do a lot of work with tesla turbines, and i have some test that need to be done with the turbine spinning at 20,000+ rpm,
also, is it possible to turn a brushless motor "backwards" like a brushed motor and make it make electricity, if it does, is it dc ( i ask cause i have heard of it producing ac and am not sure), how does rpm affect the voltage output,
questions comments concerns or anxieties are welcome
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSSK6&P=0
using the above link as an example you will notice that the motor has three wires, thats because it is a three phase AC motor.
The electric speed controller(ESC) that it requires is a DC to AC three phase inverter.
Using a brushless motor as generator wouldn't work because of the on board electronics doesn't have a rectifier to convert the AC into DC. You could remove the inverter and use it as an AC generator, but you wouldn't be able to use it as motor any more.
The Toyota prius hybrid is a good example of using motors as generators, but it is so complex the transaxle and inverter is run by a 32bit computer. The engine is run by a 32bit computer and so is the NiMh battery pack.
-dan
For hacking around, you can't beat Walmart.
Walmart carries a hand blender... the kind you put into a glass to make a smoothy. The kind that doesn't break immediately costs about $25 dollars. But the kind you are looking for is about $9. I don't know how many rpms it gets but it is nice little unit... which breaks after about a week leaving you a beautiful motor, which can operated off of a wall outlet... or will run at a slow speed by just hooking up +5V and ground to the motor terminals, which can be accessed by removing 4 screws. I wouldn't try this with a protoboard... I used a power supply from SpinStudio and a breadboard. Nothing blew up or started smoking.
I also like the motors from ultra-cheap hand held vacuum cleaners.
You can make a nice motor controller with a 5 volt relay from RadioShack(SPST Reed Relay part 275-0232)
Although these relays are rated as 5 Volt (and .5Amps at 120VAC), in reality you can control the relay directly from a Prop pin. You should probably use a diode in between the prop and the relay. Since you will be using DC, the .5Amps spec doesn't really count. My guess is that using DC, the relay will probably handle higher amps, but I don't know how to do the conversion(but I would like to know[noparse]:)[/noparse]
To do it correctly... you have to do it the way Parallax does... get yourself an HB-25 motor controller, it is easy to use and just begs to be held[noparse]:)[/noparse] This way your motor and your prop are protected from each other.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/64/Default.aspx?txtSearch=motor+controller&SortField=ProductName,ProductName
Rich
Take a look at an automotive alternator. They are 3 phase AC generators with a simple 1/2 wave rectifier to convert to DC.
___________$WMc%__________
The Truth is out there············································ BoogerWoods, FL. USA
If you've got an old PC cooling fan lying around, it is almost certainly a brushless DC motor. Not powerful enough for some of the things you want to do, but OK for learning how to control one. Cheap, too -- usually free.
· -- Carl, nn5i@arrl.net
Post Edited (Carl Hayes) : 2/20/2009 5:52:49 PM GMT
Jason
there are no magnets in standard alternators..
They do a pretty good job of explaining things.
-dan
