RFID card FYI — Parallax Forums
RFID card FYI
edited 2009-02-18 02:10 in General Discussion
Just thought I'd pass this on.. Should save anyone else destroying one to confirm.
The RFID "cards" that Parallax sells contain the RFID at the center of the card.
It is about a 2" circle at the center of the card. The rest of the card can
be shaped and modified at whim without damage to it's functionality.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
  • UghaUgha Posts: 543
    edited 2009-02-17 19:08
    Is there anything in the very center of the circle?
    edited 2009-02-17 19:37
    So far, a coil of wire at about 2"
    I haven't destroyed it to the center. *yet*
    They are extremely well glued together.
    I'll have my Chiropractor buddy toss one under his X-ray machine
    and I'll see if we can get a good Xray. [noparse]:)[/noparse]
    OBC
  • uxoriousuxorious Posts: 126
    edited 2009-02-18 01:47
    Besides the antenna (coil of wire) there will be the actual IC, probably in an EMDFN-02 plastic package that is 2.2mmx1.78mm. The IC contains the circuitry to rectify the 125Khz signal for power, generate a clock, read the data from memory, encode this data (typically Manchester format), and modulate the data back into the antenna to transmit the memory contents to the reader. Attached is a picture of an RFID read only chip that has not been attached to an antenna. I'll try to remember to bring one of my Parallax cards into work tomorrow and x-ray it.
    ~~ dRu ~~
    628 x 528 - 100K
    Oldbitcollector,
    With a very bright backlight you can see through the card. I did this and mapped my results. The coil is close, but not exactly center.
    Beau Schwabe
    IC Layout Engineer
    449 x 697 - 37K
