The Rover controller is done! — Parallax Forums
CannibalRoboticsCannibalRobotics Posts: 535
edited 2009-02-17 23:22 in Propeller 1
After several attempts and circuit board revisions (shown in the photos) I’ve arrived. SMD is the way to go.
This is a rover controller that has a four channel audio & composite video multiplexor, a compass, accelerometer, 8 input A to D and several PWM outputs and a Linx 433MHz transceiver. The RF portion of the circuit is completely isolated from the digital and video noise by placing the boards back to back in the chassis. The RF board also has it’s own power supply from the three AAA batteries. In the development stages I never could get the motor transients from the servos and drive motors to keep the radio from loosing sync. All I/O including audio/video from the cameras, PWM, Prop programming and power come through the header off of the end of the CPU board. This is also isolated by the case. In the photo, there are a couple of traces that overlapped so I had to reroute them. The four AV channels allow selection between 3 cameras or the propellor video and audio defaulted to channel 0. The board has a 3.3, 5 and 12 volt power regulators for prop, compass and Axc and 12 for the cameras that plug into the header.
The major challenge of this project has been a complete rewrite of the FullDuplexSerial component.The genius of that piece of code is how it multitasks the transmit and receive lines. For this RF implementation I wanted one antenna so I had only one data line and it is constantly switching between T & R modes. This proved to be a huge challenge as there are delays between switching modes caused by the electronics then the physics of re-syncing the signals. It was also particularly challenging because timing is so tight, it had to be done in prop assembly, (Yeah Jim!) It is a packet based communication protocol that has both packet indexing and checksum for every pack. The communications code runs on it’s own cog. Other cogs communicate with it through a soft interface very much like the FullDuplexSerial. Each communication end has a buffer that is mirrored on the other side so cog A writes data to it’s transmit buffer and a few milliseconds later that data just shows up on the receive buffer at the opposite end.
I’ll post more later, probably on my website. These will include photos of the actual rover, the other end of the comm link and a few videos of the whole thing in action.
Enjoy!
Signature space for rent, only $1.
Send cash and signature to CannibalRobotics.
2200 x 1397 - 334K
2419 x 1038 - 550K
1353 x 856 - 149K
1616 x 1442 - 385K
1706 x 1010 - 353K
  • jazzedjazzed Posts: 11,803
    edited 2009-02-17 19:42
    Nice prototyping. I like the enclosure concept. Do the electronics generate any heat? What kind of wireless range do you get?
    --Steve
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2009-02-17 20:07
    No problem on heat buildup since I distributed the regs around the board.
    I have not formally tested the wireless range yet but I should start that in earnest next week late. I'll have to get back to you on that. Linx says several thousand feet but I'm pretty sure that's not going to happen for 10Kbit which is what I've been running in the shop. The communications protocol has speed and packet size adjustment and 10Kbit is right at the top end of the spec for the LT433 transceivers. I'm thinking that range is going to be a mushy answer bracketed with speed settings and data package sizes.
    I'll let you know.
    edited 2009-02-17 20:08
    I'll let you know.
  • parts-man73parts-man73 Posts: 830
    edited 2009-02-17 20:11
    I really like that aluminum housing. I Googled "context engineering" and found that company, but you have to email them for a quote. Where'd you get yours? was it custom made for this project? The impression I get from their website is that their enclosures are custom made to order, which usually means $$$
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • sstone86sstone86 Posts: 19
    edited 2009-02-17 20:58
    parts-man73 said...
    They usually stock these in store but if you don't have one near you click below:
    ·http://shop4.frys.com/product/2090760?site=sr:SEARCH:MAIN_RSLT_PG
    edited 2009-02-17 21:00
    perfect, that's more affordable than I'd expect. No Fry's out here where I live in NY, but I can order online.
    Thank you!
    Brian
    edited 2009-02-17 21:57
    Best part is that expressPCB miniboards slip right in to the rails.
  • RaymanRayman Posts: 16,461
    Wow, an enclosure for the expressPCB boards! I looked all over for something like this! Sweet.
    You could probably just cut it to the right length with a bandsaw too...
