Encoder Compatability
I does anyone know if this encoder is compatible with the propeller chip... from wat i could tell I believe it is but can someone please double check..
http://www.reprap.org/bin/view/Main/Magnetic_Rotary_Encoder_1_0
Thank you
Technic-R-C
Thank you
Technic-R-C
What is your application?
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
The purpose of the encoder will be
-to calculate the velocity of a wheel on·a homemade·electric scooter
-to determine·wheter or not·a wheel is stalling (overexcessive wheel rotation speed when wheel is not touching ground)
-to determine the direction·that the·wheel is turning.·
By the way, what do you mean by the IC being a 5V level?· I'm rather new to electronics and if you could clarify·your statement I would really appreciate it.
Thank you
Technic-R-C
Thank you,
Technic-R-C
First - determine what signals you want to interface to on the magnetic encoder IC. Then we can provide further advice. Some translation maybe complicated (involve another IC or multiple components) but some translation can be as easy as inline resistor for limiting the current into the Propeller input.
www.tdswieter.com
