SX/B Address Calc Error? — Parallax Forums
pjvpjv Posts: 1,903
edited 2009-02-17 13:37 in General Discussion
Hi All;
When I'm using the new SX/B conversion command HEXVAL in direct address mode, I believe the wrong address is calculated.... off by -1.
HEXVAL @__Param3, K compiles (first line) to:
1066  00BC  0C0B        MOV FSR,#(__PARAM3-1)          ;  HEXVAL @__Param3, K
      00BD  0024
and that points to __Param2, not to __Param3
I have not checked the other conversion commands.
Cheers,
Peter (pjv)
  • BeanBean Posts: 8,129
    edited 2009-02-16 23:46
    Peter,
    Yeah, not sure how that "-1" got in there. I will fix this.
    Thanks.
    Bean.
    There is a fine line between arrogance and confidence. Make sure you don't cross it...
  • pjvpjv Posts: 1,903
    edited 2009-02-17 00:52
    Thanks Terry;
    On checking, I note that the same happens on HEXSTR.
    Cheers,
    Peter (pjv)
    Peter,
    These should be fixed in version 2.00.12 that I have just posted.
    Bean.
