Connectors — Parallax Forums
Connectors
bdrew7bdrew7 Posts: 38
edited 2009-02-17 15:58 in General Discussion
Does anyone know the manufacturer and part number for the female plugs used on the end of the servo motor cables?
Thanks.
bdrew
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2009-02-16 16:19
    Yes,
    get them at digikey. I buy them in three position format for servos and four position for cameras.
    You also need to order the female pin sets separately.
    Here are the lines out of my order.
    Item Qnty Part Description B/O Price Extended
    1 10 WM2802-ND CONN HOUSING 4POS .100 SINGLE 0 0.65400 $6.54
    2 20 WM2801-ND CONN HOUSING 3POS .100 SINGLE 0 0.62800 $12.56
    3 100 WM2562-ND CONN TERM FEMALE 24-30AWG TIN 0 0.07680 $7.60
    Cheers
    Jim-
    Signature space for rent, only $1.
    Send cash and signature to CannibalRobotics.
  • Carl HayesCarl Hayes Posts: 841
    Have a look at Page 1370 of the current Mouser catalog, figure A,
    http://www.mouser.com/catalog/637/1370.pdf
    · -- Carl, nn5i@arrl.net
    edited 2009-02-16 17:05
    If you don't feel like constructing your own cables, Parallax's "LCD Extension Cables" (#805-00011 and #805-00012) are reasonably-priced alternatives that come with the Black/Red/White color-coded wire. If you don't need the connector at both ends, just cut one in half, and you'll have two cables.
  • RDL2004RDL2004 Posts: 2,554
    edited 2009-02-16 17:32
    http://forums.parallax.com/showthread.php?p=577638
    - Rick
    edited 2009-02-16 18:38
    The one disadvantage to the digikey version is that they are not 'keyed'. If you look closely at a servo connection two of the corners are chamfered to a 45 deg angle. This prevents them from being inserted into a radio controller improperly. If your just hooking them up to a header then these will do fine.
    Cheers,
    Jim-
  • bdrew7bdrew7 Posts: 38
    edited 2009-02-16 18:54
    Thanks to everyone for the information.· I need to make some custom lengths.
    Bernard
    Bernard, your duplicate post in the BASIC Stamps forum has been removed. Please do not cross-post messages. Take care.
    Parallax Engineering
