OK I need help now soon, hint hint Ken G. or anyone else!
I'm having trouble in sending a 12 bit code to a robot via a BS2px24, this is a binary code that needs to be sent:
0110 1000 0010 [noparse][[/noparse]Hex $682]
The timing is as such:
MarkOne=1.84mS
SpaceOne=1.952mS
MarkZero=6.74mS
SpaceZero=1.953mS
Now I know the Stamp is fast enough to handle this but I just can't seam to get it to accept the code, I'm using the PULSOUT command to send it but should I be using something else or I may have the timing set wrong on my end, but when connected to the oscop and I only see the lowering "grounding' of the pin to send the signal and nothing else. Sorry I cannot say what the robot is, but any code that would help me out here would be greatly appreciated or just point me in the right direction and I'll take it from there. And yes I have read all the manuals that I downloaded with no luck on this project or I just missed something in them.
Like I said I may have the calculations wrong in converting the timing for the duration on the PULSOUT command but not sure. this is what I came up with for the BS2px24.
MarkOne=1.84mS = 2300
SpaceOne=1.952mS = 2400
MarkZero=6.74mS = 8425
SpaceZero=1.953mS = 2441.25
Once this robot MOD is complete I'll post it on the complete project forum.
Thanks in advance,
Jax
If a robot has a screw then it must be romoved and hacked into..
MarkOne=1.84mS
SpaceOne=1.952mS
MarkZero=6.74mS
SpaceZero=1.953mS
Thanks in advance,
Jax
Jax
Jax
Jax
