Help with Accelermoter/Servo Control
I'm having great fun (and success) in the Propeller world, OBEX is my best friend! Anyway, I'm trying to have proportional servo control based on the accelerometer. I get a value called size that goes from 0 (horizontal) to 45 (vertical) and a value called deg which goes 0-360. I used Servo32v3 for servo control. My servo has 1000 as the bottom and 2000 as the top, I've tested this elsewhere. I used a method called ChooseE to choose the direction the servo will move, 1 is down (1500-1000) and 2 is up (1500-2000). I have the up side working, but the down part doesn't! I have an update accel method, and it is straight from the example that came with it.
My code:
Update the accelerometer (this is run in its own cog)
ChooseE
Thanks!!
My code:
repeat
waitcnt(cnt + 1_000_000) 'To make sure you can read the TV
!outa[noparse][[/noparse]23] 'If you don't have a TV this says everythings working fine.
term.dec(deg)
term.str(string(" ")) 'These four commands format and output text to the TV
term.dec(size)
term.str(string(13))
elevator := chooseE
if elevator == 1
outa[noparse][[/noparse]17] := 1
SERVO.Set(5,2000)
if elevator == 2
outa[noparse][[/noparse]18] := 1
SERVO.Set(5,(size*500)/45+1500)
else
outa[noparse][[/noparse]17] := 0
outa[noparse][[/noparse]18] := 0
SERVO.Set(5,1500)
PUB UpdateAccel | raw, mg, G_scale, temp
G_scale := 2000/(256/3)
repeat
raw := acc.ro 'Get raw value for acceleration
raw := raw / clk_scale 'the magnitude, really
size := raw / G_scale 'scale mg value for screen display '
temp := acc.theta >> 19 'scale 32-bit value to a 13-bit value
deg := temp*360/8192
if cnt // 3000000 == 0
dira[noparse][[/noparse]18]~~
!outa[noparse][[/noparse]dira]
ChooseE
pub ChooseE
if deg > 90
if deg < 270
term.str(string("down"))
return 1
else
else
if deg < 90
term.str(string("up"))
return 2
if deg > 270
return 2
else
return 3
Thanks!!
Then the code does this:
The 'different stuff' will happen, because elevator is 1, not 2, and this erases the result from the very first IF.
You can change your code to use explicit IFs for all three cases, OR use ELSEIF, like this:
Jason
Post Edited (JasonDorie) : 2/15/2009 10:04:34 PM GMT
PUB ChoosE case degree 90..270: term.str(string("down")) return 1 0..89 : term.str(string("up")) return 2 271..360 : term.str(string("up")) return 2 return 3
