XBee Assist
I'm stuck on my first XBee project, and looking for pointers into where I should look for errors.
Here's where I am in code:
It prints Debug 1 to console and never gets to Debug 2. Ergo, I assume it is stuck waiting for the rx buffer to fill, i.e. there is nothing coming in.
Hookup is very simple.
vcc p1 - 3.3
dout p2 - prop p20
din p3 - prop p21
dtr p9 - gnd (active high)
gnd p10 - gnd
rts p16 - gnd (active high)
I've checked the device on the usb breakout board and always reset to default before plugging it in.
Thoughts?
edit: Bonus question - Is the FullDuplexSerial object FIFO or FILO?
Post Edited (RICoder) : 2/15/2009 6:41:47 PM GMT
objDebug.start(PIN_SERIAL_RX, PIN_SERIAL_TX, 0, 9600) ' Initialize comms from Prop to PC
objXBee.start(PIN_RX, PIN_TX, 0, 9600) ' XBee Comms - RX,TX, Mode, Baud
objXBee.AT_Init ' Initialize for fast AT command use - 5 second delay to perform
'ASK FOR ADDRESS
objXBee.AT_Config (string ("ATDL"))
'READ IT IN
objDebug.str (string ("debug 1"))
btRX := objXBee.RX
lAddressLow := btRX << 24
objDebug.str (string ("debug 2"))
btRX := objXBee.RX
lAddressLow := lAddressLow | btRX << 16
vcc p1 - 3.3
dout p2 - prop p20
din p3 - prop p21
gnd p10 - gnd
Thoughts?
Then you just need to feed in what ever you want with just the serial driver, with out the xbee code.
So did i for my RC remote setup.
I have a new question:· When I send it the command to set the XBee module attribute (like the DL or MY) does it actually send out an "OK" as you see in the tool from XBee?
I found a week solder joint on my breakout board on the TX pin, and I think that must be what the problem is, because now I see results.· That said, the results are not at all what I would expect to see.· Hence my update (is the FullDuplexSerial object FIFO or FILO....and is the "OK" coming out).
Yes. You can see this if you communicate with the XBee using a terminal program as well - it's not generated by the XBee tool.
Take a look at the PBasic program for reading RSSI on page 24 of this document:
selmaware.com/appbee/AppBee_Doc.PDF
You'll see a routine for handling that "OK" to keep it from being read as part of RSSI.
