The Aptera electric car and calculations
http://autos.yahoo.com/articles/autos_content_landing_pages/857/exclusive-aptera-2e
Looking at this site http://www.windways.org/aptera/
It claims the new Apt era uses just 80 watt hours per mile.
12,000 miles on just $125.00 in electric at .13 cents per KW
Looking at a typical 1HP DC motor it uses 90 amps at 12V at no load 1080 Watts
Are they telling me this thing has a 1/10 HP motor?
If a 2 ohm resistor draws 72 watts at 12V (6 amps) they are telling me on that much power I can drive this thing a mile?
Did they really break the law of physics or am I missing something?
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
But the thing is the overall technology to drive electric costs more. Even just a decent 72V 400-500A motor and controller will run around $1500. Which without a transmission is a very small car motor. 2.5K plus for a decent setup for a vehicle. You'll end up swapping batteries like you do brakes in a normal car. Ride it hard and it needs changed once a year, might get 3-5 if your lucky with depriciated performance. Thats not cheap, whether it be standard deep cycles or expensive battery array's.
Sorry but it just starts me on a rant when I see those calculators which show $2000 a year upkeep for a gas vehicle, and $600 for an electric conversion. Its basicly taking the drive train out of the equation, as if electric never fails. You still have normal maintance, except you wont be able to find a shop in town which will "power cycle and normalize" the batteries. You'll have to do all the labor.
Your average high output DC motor will draw about 200amps at 12-15HP @72V levels. Which is about average cruising. Most of the larger versions run around 140V, such as in vehicles.
I dunno, electric has a long ways to go before its truly a viable option. You cant just stop in at a recharge station and 10 minutes later your on your way. And with only 400-600 recharges before your replacing batteries it definately isnt any cheaper.
For the 10-20 miles per day driver it could possibly be a good choice.
I am trying to figure out how they are supposily getting 80 Watt-Hours. But If they are truly describing it as Watt-Hours, its of course nearly absurd. Seems they added some quasi-math in there. Except they add their magic number per mile. So taken they are driving 60mph. Thats like 4800 watt's per hour. Or about 67 AH.
Which isnt totatly fantasy. Its atleast plausible. Still means you'll need a trailer of battiers to drive more than an hour or so.
As was pointed out, the battery technology is still the kicker. We are still nowhere near low-cost, high number of cycles, light weight, compact battery banks. But, its lots of fun playing and better than hanging out at the tavern!
I used a 19 HP jet starter motor. 36 volts, 400 amps max. Don't confuse instantaneous "watts" with "watt-hours". One is power, the other is energy.
Cheers,
Tom Sisk
http://www.siskconsult.com
Gah! 90 amps under no load? 70% efficiency when no work is being accomplished, I'd look for a different motor.
Lets see, they claim 80 watt hours per mile. They mention 55 mph on their website. That is 80 * 55 = 4,400 watt hours or 4.4 kwh/hr. Assume 85% efficiency and that is 3,740 watt hours to the wheel OR about 5 hp. So, 5 hp to maintain 55 mph on smooth level ground with very good aerodynamics seems plausible to me.
Now, did I screw up the math???
Rich H
-dan
http://www.sevcon.com/pages/productoverview.html
http://curtisinst.com/index.cfm?fuseaction=cProducts.dspProductCategory&catID=8
http://www.catlifttruck.com.sg/products/producttypes.php?product_category_id=3&product_type_id=9
http://www.crown.com/usa/products/usa_electric_forklift/sit_down_counterbalance/FC_4500_Series/features.html
however the curios thing is that dc motors pull more current at higher hp compared to a 3p ac motor. you could use a 10 hp 3ph motor in the two front hubs and they only would pull 22 amps a piece @230v, compared to dc at 28+ amps @ 230v, 3p motors also have the ability to use regenitve breaking so they can store braking force.
Also is terribly harder to build a brake regen from 3phase ac, which inverts once again to loose even more gain.
And you can get brushless motors right?
Parallax Engineering
