RCTime Touch Sensor
I can't remember if anyone has suggested this before, so i figured i would post it anyway. It is just a simple way to make a touch switch using the rc circuit and an additional lead.
Basically, when the sensor lead is touched, it changes the normally constant value being read by rctime from the resistor and capacitor combination. That change in value is used to trigger an event.
To get the proper resistor and cap values is from experimenting, though there is a mathematical approach explained in the rctime syntax. I used a 10nf ceramic cap, and a 47k resistor to give a fair, but not large resolution.
The sensor lead itself is a resistor with one end inserted into a piece of conductive foam. It could be just a wire by itself, or attatched to anything conductive.
The constant value of the circuit seems to drift a bit after a period of time, but if the sense threshold is kept fairly wide, it should not matter.
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM1}
result VAR Word
Test:
HIGH 0 ' charge the cap
PAUSE 1
RCTIME 0, 1, result ' measure RC discharge time
DEBUG DEC ? result ' display result
PAUSE 500
IF result > 340 OR result < 318 THEN
DEBUG " TOUCH DETECTED ",CR
END
ELSE : GOTO test
ENDIF
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, uOLED-IOC, eProto for SunSPOT, BitScope
www.tdswieter.com
Perhaps this could be adjusted just a little bit to become a primitive lie detector?
(IIRC, Galvanic skin response.) Could be a fun project.
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
