About making the HYDRA into a radio
While I was reading in the book an idea hit me. Since you can generate AM/FM sgnals and connect an antenna, maybe it's possible to make a radio or a fm-transmitter of the HYDRA system. Would that be possible? It would be good to be able to send the video or audio wirelessly.
it possible to cycle the frequency and make musical notes.
After converting the notes to Bach and several classical
segments, I discovered it acted as a short range transmitter
using an AM radio tuned to the low end band. The range is
only about a foot or two, but there are antennae and ways
to increase the signal. You can hear the music but not with
the original clarity of feeding to an amp circuit directly. It
should be possible to do the same with one of the stamps
or Hydra.
humanoido
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
