BASIC Stamp 2P 40 Help!
Can someone please explain to me how to use the BS2p40?
I don't get the whole MAINIO and AUXIO thing. When I try to light an LED on p15 it dosn't even work. I am doing this on the PDB for the BASIC Stamp. Please help!
Thanks!
Dan Taylor
Thanks!
Dan Taylor
Dan Taylor
Be careful with the pin mapping from the BS2P40 on the professional development board. Look at the pin mapping on page 6 of the PDP instructions. It can be confusing when you use a BS2p40.
The 24 pin BASIC Stamps have 16 i/o pins, usually numbered from p0 to p15, and those 16 i/o's go from p0 to p7 down one side of the package and from p8 to p15 on the other side of the package. On the PDB they connect to the 16 places on the plugin terminal strip labeled X15, and correspondingly labeled "0" to "15". Very straightforward.
Now, look at the BS2p40 package. The module itself has MAINIO, logical pins p0 to p15 running down one side and auxio, logical pins x0 to x15 running up the other side. When you install a BS2p40 on the PDB, it ends up with 8 of the mainio, p0 to p7, and 8 of the auxio, x8 to x15, on the connector x15, instead of p0 to p15 as it was on the 24 pin stamps. But the PDB docs still refer to those terminals as they come out on the PDB as P0 to P15. And the remaining pins of MAINIO, p7 to p15 and of AUXIO, x0 to x7 end up on the socket that is up at the end of the PDB and lableled "AUXIO". Confusing? Each of those terminal blocks ends up with half of the MAINIO and half of the AUXIO signals from the BS2p40. The designations on the terminals labled "AUXIO" run from RB0 to RB7 and RC0 to RC7, as they are on the SX chip that might share those terminals.
The PDB manual refers to the logical MAINIO pins as M0 to M15 and AUXIO from as A0 to A15, however, in most of the examples you will see, the pins designations as shown on the BS2p40 schematic are used, p0 to p15 for MAINIO and x0 to x15 for AUXIO. Confusing again?!
All pins on MAINIO and AUXIO come up as inputs at power up. Experimenting is one thing, but in any final application, all unconnected pins should be made outputs in one state or another in order to minimize current drain.
Tracy Allen
www.emesystems.com
If, for example, you have a subroutine or section of code that only uses auxio pins, normally, you could put the auxio command at the beginning and the mainio at the end and all would run fine. When you use pollin, you have to be sure to auxio/mainio every single line that involves a pin, or very strange problems arise.
I try to always design my p40 programs so that I use as few aux pins, and·as seldom as possible, on pages with pollin as it cuts down the number of potential missed auxio/mainio lines.
Once you get used to how it works, the p40 is really nice to work with.
It does however seem to give more grief on my PDB than when I have it on a big breadboard or in a project.
Darlene
Dan Taylor
I'm curious about the issues you've had with POLLIN. Can you be more specific about it, or give a snippet, for example, does it happen when coupled to a POLLOUT or POLLRUN? I've not been aware of bugs with it intrinsically, although the inclusion of auxio and polling does entail a new class of pitfalls. I most often use POLLIN in conjunction with POLLWAIT, or in latched mode in conjuction with the scratchpad RAM polling bits.
Tracy Allen
www.emesystems.com
If the program is executing a subroutine for example, where all the calls are to auxio pins, and you have auxio at the beginning of the subroutine and mainio at the end,·without pollin, that works fine. But·if you don't have mainio immediately before the pollin line, it will look at the pollin pin number as an aux pin when it checks while·between the lines in the subroutine. If you do have mainio·immediately before·pollin (assuming it's on a mainio pin), then...
When it goes back to the next line in the subroutine where it came from, it won't know to go back to auxio. I also have had better luck keeping the pollin pin in the mainio range.
Here's a snippet of code from a subroutine, which in turn, calls another subroutine. I chose pin usage so that the called subroutine (and it's a long one)·can use all mainio pins, otherwise I'd have 100 auxio/mainio lines in it.·This subroutine only has to check on 1 auxio pin, but look how much space is wasted on auxio/mainio lines, without which, it won't work.
DsplUpdt:
·· PAUSE 20
· AUXIO
· IF OUT12 = 0 THEN
· MAINIO
· SEROUT LcdPin, BM, 10, [noparse][[/noparse]145, "OFF"]
· AUXIO
· ELSEIF OUT12 = 1 THEN
· MAINIO
· SEROUT LcdPin, BM, 10, [noparse][[/noparse]145, " ON"]
· ENDIF
·MAINIO
·· GOSUB ResetConfig1
··· PAUSE 20
· GOSUB Convert1
······· Rslt1 = Rslt
· SEROUT LcdPin, BM, [noparse][[/noparse]168, "··· "]
·· PAUSE 20
· SEROUT LcdPin, BM, 10, [noparse][[/noparse]168,DEC Rslt1]
·· PAUSE 20
For every line that refers to a pin, you have to have auxio/mainio right before and after or the program just gets lost.
It's not a bug, but just a pita nuance of how pollin works. ... the new class of pitfalls, as you call them.·
Once I·developed a sufficient understanding of how pollin worked, I understood why·my original·program code·ran so wierd and then crashed, and what to do to make it work as intended.
This snippet is the option on the options page that the above display update subroutine keeps track of in the main program.
Option2:
· SEROUT LcdPin, BM, [noparse][[/noparse]128, "OPTION-2:·· AUTO O2 "]
· SEROUT LcdPin, BM, [noparse][[/noparse]148, "· * * * * * * * * * "]
· SEROUT LcdPin, BM, [noparse][[/noparse]168, "BTN-1··· NEXT OPTION"]
· SEROUT LcdPin, BM, [noparse][[/noparse]188, "BTN-3·· TO SET VALUE"]
· PAUSE 600
· DO
· LOOP UNTIL IN8 = 0 OR IN7 = 0
· IF IN7 = 0 THEN
· RUN 7
· ENDIF
·Option2b:
· SEROUT LcdPin, BM, [noparse][[/noparse]128, "· AUTO· O2 IS:····· "]
· SEROUT LcdPin, BM, [noparse][[/noparse]148, " BUTTON-1· =· ON··· "]
· SEROUT LcdPin, BM, [noparse][[/noparse]168, " BUTTON-2· =· OFF·· "]
· SEROUT LcdPin, BM, [noparse][[/noparse]188, "BOTTON-3·· TO· SKIP "]
· AUXIO
· IF OUT12 = 0 THEN
· MAINIO
· SEROUT LcdPin, BM, [noparse][[/noparse]145, "OFF"]
· AUXIO
· MAINIO
· SEROUT LcdPin, BM, [noparse][[/noparse]145, " ON"]
· ENDIF
·PAUSE 800
·MAINIO
·DO
·LOOP UNTIL IN7 = 0 OR IN9 = 0 OR IN8 = 0
· IF IN7 = 0 THEN
· AUXIO
· HIGH 12
· MAINIO
· SEROUT LcdPin, BM, [noparse][[/noparse]145, "·· "]
· ELSEIF IN9 = 0 THEN
· AUXIO
· LOW 12
· MAINIO
·ENDIF
·PAUSE 600
·DO
·LOOP UNTIL IN8 = 0
·IF IN8 = 0 THEN
·GOTO Option2
·ENDIF
The p40 when using the aux pins, is just totally intollerant of omissions.
Darlene
Also, to save execution time, if you are concerned about bank switches during POLL operations, you can check the bank flag before any bank-critical command and swtich only if the flag isn't where you want (the bank switch actually takes quite a bit of time to execute, so there are a number of good reasons for cutting down on bank switches). In other words, even if a given chunk of code presumes that correct bank is in play, right before an op like SEROUT, you check the bank status anyway.
Darlene, I don't see any POLLIN commands there in your snippets. Is POLLing more trouble than just aux-and mainio?
Once a pin has been set for polling, say on AUXIO, the program can switch back to MAINIO and the polling action on the selected auxio pin(s) will take place in the background. For example,
Activates a latched connection between x15 and x14, so x14 will start low, but it will go high and stay there (latched, due to pollmode 10) as soon as x15 goes low (within the ~10ms granularity of the main loop), without any further program intervention. That happens even though the main program DO:LOOP stays in mainio. The caveat there is that the MAINIO/AUXIO switch has to be in the correct position when selecting the pins to use for POLLIN or POLLOUT.
like Zoot says, something like,
can maybe be shortened to a version with fewer flips from main to aux, as in,
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 2/20/2009 5:57:52 AM GMT
When I get home from work, I'll post it.
Darlene
see this thread:
http://forums.parallax.com/showthread.php?p=767204
Andrew Williams
WBA Consulting
IT / Web / PCB / Audio
