programming other boards with professional dev board — Parallax Forums
CapdiamontCapdiamont Posts: 218
edited 2009-02-14 18:58 in Propeller 1
Is it possible to program other proto boards if i don't have the eeprom, and dip prop chip installed?
  • dMajodMajo Posts: 862
    Yes, I have done it by removing the DIP Prop and connecting the other board through a 0.5m shielded cable soldered (rx,tx,rst,gnd) to an other dip40 socket connected to the PDB (no need to remove the eeprom)
    Unfortunately the PDB's rs232 port have only the 2 channel max3232 so the dtr to reset the prop is not present
