serial time communications between 2 basicstamps
we use 2 basicstamps
basicstamp1 send time and date by serial communication to stamp2
Stamp1 Send
HIGH 11:SEROUT 10\11,16780,[noparse][[/noparse]"M",HEX2 Month]
HIGH 11:SEROUT 10\11,16780,[noparse][[/noparse]"D",HEX2 Date]
HIGH 11:SEROUT 10\11,16780,[noparse][[/noparse]"U",HEX2 Hours]
HIGH 11:SEROUT 10\11,16780,[noparse][[/noparse]"N",HEX2 Minutes]
stamp2 received
serial·············· VAR Byte(1)
SERIN 8\9,16780,1000,nodata,[noparse][[/noparse]STR serial\3]
i receive the following string in variable serial
M02
D14
U10
N46
IF (serial(0)="M") THEN '·month
····· Month = serial(1) & serial(2)
ENDIF
I want to remove the M,D,U,N and store the month in a integer variable, how can i do this
regards,
· Manu
Stamp1 Send
stamp2 received
M02
D14
U10
N46
ENDIF
regards,
· Manu
month=(serial(1)-$30) * 10 + (serial(2)-$30) ' this takes your second character "0" as in the month example subtracts $30 [noparse][[/noparse]converts if from ASCII to binary]
' multiples result by 10 then takes the third character "2" subtracts $30 [noparse][[/noparse]ASCII=>Binary] and adds that in
' Tmp now holds the value of 2 [noparse][[/noparse]for the month example]
ENDIF
Smile ... It increases your face value!
Post Edited (MrBi11) : 2/14/2009 5:25:30 PM GMT
it should be fine at 2400, otherwise try 1200 bps...
'it takes advantage of the formatters in the SERIN command - very useful for this kind of thing...
'sorry i cant test it first, anyone else feel free to chip in and correct it if need be [noparse]:)[/noparse]
'STAMP 1 TRANSMIT...
month var byte
date var byte
hours var byte
minutes var byte
'Stamp1 Send
HIGH 11:SEROUT 10\11,16780,[noparse][[/noparse] Month,CR, date,CR,Hours,CR, Minutes,CR]
'···the·CR's are just used to break the hex data bytes apart, they must be used...
'·· the serin command below automatically moves the incoming byte to the next variable when a non numeric byte is received...
STAMP·2 RECEIVE...
month var byte
date var byte
hours var byte
minutes var byte
'stamp2 should receive and place the data into the variables as shown below,
nodata:
SERIN 8\9,16780,5000,nodata,[noparse][[/noparse]hex month, hex date, hex hours, hex minutes]
debug cr, hex2 month, tab, hex2 date, tab, hex2 hours, tab, hex2 minutes
goto nodata
'see the manual for the SERIN instruction and appendix C for help (its a bit confusing though).
'Once you get the gist of how this works, you will see what a very powerful instruction the SERIN command is 'with all of the formatters you can use with it.
hope it works for you...
cheers, Chris
