Lego Mindstorm and the Propeller - Anybody looked at the combo
Hello,
My son has a Lego Mindstorm (NXT). Anybody tried hooking it up (communicate) with a propeller?
I believe NXT can communicate via I2C. But before I dive into the project I thought I would trawl for any top tips and examples (I hope I'm not being lazy, I think they call it knowledge sharing)
Cheers
Eric
Cheers
Eric
http://mindstorms.lego.com/Overview/NXTreme.aspx
http://en.wikipedia.org/wiki/Lego_Mindstorms_NXT
At the end of the wikipedia page there's a pinout of the connectors used, and yes you're right, it does have I2C (and RS485)
Hope this helps!
Cheers!
Paul Rowntree
Xander
| To know recursion, you must first know recursion.
| Current projects and ramblings: I'd Rather Be Building Robots
the real issue with putting that many on one bus·segment though,·is slave address conflicts.
Post Edited (InSilico) : 2/15/2009 2:35:02 AM GMT
I was just wondering if anyone made progress with this idea. My son is a little young to deal with a laptop but I now have a cursor and VGA controller for my Prop, so I thought maybe, just maybe, it might be possible to make a simple Prop-based system that would allow him to click and play.
thanks,
Mark
I modified Hippy's I2C slave software to work against it - remove some functionality that the master can't handle and fixed a couple of bugs.
You can also attach some I2C sensors directly to the Nxt - I expect for example the SRF02 sonar to work.
I was lazy and used spin-- it's just barely fast enough when using one of the first 9 pins... however I had thoughts about using the counters for the carrier frequency.
Nothing new for getting a Propeller to talk to LEGO Mindstorm devices?
Trying to learn robotic to kids I think it will be very usefull to have a shield and program .
It will help to make Propeller use attractive for this kids. They like building with Lego blocks.
I found something for the Arduino (at Openelectrons.com) but nothing for the Propeller.
Jean Paul
I've been pondering the same thing for a long time, but have not actually tried to make any progress yet.
There's a device that allows the Mindstorms to communicate via Xbee, so that could provide a bridge of sorts or at least some clues about how to make an interface:
http://robomatter.com/Shop-By-Robot/NXT-Robots/Hardware/NXTBee-Sensor
I came across the following link that might be helpful if you are so inclined to make your own sensors:
http://www.extremenxt.com/lego.htm
There are also some hardware schematics, etc. at the bottom of the following page:
http://www.legoengineering.com/knowledgemanager/questions/154/Where+can+I+find+technical+specifications+for+the+NXT+brick%3F
Obviously, if the Arduino can interface with Mindstorms, then the Propeller can do it, too, but I suppose it's just a matter of working out what sort of handshaking must take place.
I haven't tried this yet but it is on my list of things to do.
As I read this, the idea is to replace the LEGO brick with a propeller based board (and connectors) and hook it up to the NXT (or RCX) sensors and motors?
You would think it could be done.
Maybe a QuickStart with a protoboard and a number of the RJ-xx (they use something non-standard) connectors. The hardware investment is certainly less than buying a brick. Someplace, I had found some pretty detailed infor on the interfaces and if we can get to the Arduino stuff, that should be re-creatable on the Prop.
12blocks would be a good coding environment. It's drag and drop and let's you graduate to SPIN. I haven't looked at it but there is some sort of support in 12Blocks for the Mindstorm - it could just be a skeleton for future development.
Maybe it's time to reorganize my To-Do list (again).
