SXB 2.0 bug using NOT
Bean,
The simple statement __param4 = not __param2 compiles into
·· 145· =00000014······ MainLoop:······················· ;MainLoop:
·· 146·················
·· 147· 0014· 024B······· MOV W,/__PARAM2··············· ;· __param4 = not __param2
·· 148·················
·· 149· 0015· 0010······· JMP @MainLoop················· ;· goto MainLoop
······· 0016· 0A14
There is a missing MOV __PARAM4,W
regards peter
······· 0016· 0A14
regards peter
Bad spellers of the world untie!
What does work is
·w = not __param2
·__param4 = w
as a workaround for now.
I think this bug originates from an earlier bugfix
where a MOV W,W had to be removed.
regards peter
Thanks for catching that. I screwed up when I added the code to support "W" in 2.00.09. I will post version 2.00.11 today with the fix.
Bean.
There is a fine line between arrogance and confidence. Make sure you don't cross it...
