Conductive Foam Pressure Sensor. Insulator — Parallax Forums
EzsynnEzsynn Posts: 119
edited 2009-02-15 04:41 in Accessories
Okey, I made pressure sensor but the last thing I need is a sheet insulator.
To wrap around and insulate the sensor.
What to use?
BWIN ON DA POWAH WIFIN U!!!
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2009-02-13 06:58
    Ezsynn,
    Can you be a little more descriptive of your particular sensor application? That might help us provide a better, more informative answer.
    Beau Schwabe
    IC Layout Engineer
    edited 2009-02-13 08:01
    I made these from conductive foam, the kind that holds ICs and
    prevents their static electricity zapping. It was easy to use two
    small circular copper plates. Solder a wire to each plate and lead
    it to a Basic Stamp rc circuit. To ensure repeat reliability, choose
    the conductive foam that rebounds the quickest. There are several
    varieties in use. Wrap the exterior with thin material such as cloth
    which is an insulator. If the parts are held in a small tube, like a
    pen body, a thick formed wire can act like the supporting active
    linkage and push on the foam.
    humanoido
    Post Edited (humanoido) : 2/13/2009 8:07:01 AM GMT
  • Cole LoganCole Logan Posts: 196
    edited 2009-02-13 14:01
    I haven't built one but I would think that you would be able to use some plastic food wrap aka cling wrap.
    Something like this
  • EzsynnEzsynn Posts: 119
    Cole Logan said...
    Nice One Cole.
