Got a BS2 and an oscilloscope?
So I'm trying to debug an issue I'm having interfacing to the new MLX90614 temperature sensor. I could really use some quick and relatively easy help if someone is up for it. All you need is a BS2, an oscilloscope that can export results, and a little bit of boredom. [noparse]:)[/noparse] You do NOT need the MLX sensor to help me out here.
I am attaching some sample code provided by Parallax for doing a simple demo with the BS2/MLX. All I care about getting is an oscilloscope reading of how the SEROUT sequence looks when running this program.
I would be eternally grateful to anyone feeling like helping me out here.
If you have the Parallax USB oscilloscope, that'd be great, because that's what I have, so I could very easily import the saved results. But anything will help.
Thanks in advance!
Thanks in advance!
But, anyway.· I have a CRT-based oscilloscope.·
What are you angling at SEROUT-wise?
Post Edit -- I knew I saw you on about this in another Subject.· As I see it, you cannot·connect the MLX90614 directly·to a PC serial port.· It interfaces with a Stamp directly using TTL voltage levels.· You should be able to establish a PC-to-MLX link using a MAX232 (or MAX233, for fewer parts) TTL-to-RS232 converter.
Post Edited (PJ Allen) : 2/13/2009 3:46:25 AM GMT
I'm interested in seeing what the SEROUT sequence looks like so I can verify that my chip (non-BS2) is putting out the same thing. I have yet to be able to get my MLX to do anything at all, so I'm starting to suspect maybe it's bad. If I can confirm that what a BS2 puts out is the same thing I'm putting out, I can at least stop trying so many slightly different things...
The MAX232 is an inverter --·on the·logic (TTL/CMOS)·side it's·HI in, negative voltage out;·logic·LO in, postive voltage out; on the RS232 side it's negative voltage in,·logic HI out, positive voltage in, logic LO out.·
The idle state (nothing going on)·for RS232 is negative voltage (not Ground), so the·logic idle state is +5.
In some cases, a Stamp can be connected to a PC (through a 22K resistor), and then "Inverted" is used.
Does your PICAXE have True and Inverted baudmodes?··The MLX is waiting for 9600, 8-N-1, True.· If not one then try the other, "roll your data."· It wouldn't have been a good idea to connect the MLX directly to a PC serial port (if you've done that.)
Post Edit -- If you have a MAX232/233, you should give that a try.
Post Edited (PJ Allen) : 2/13/2009 12:28:59 PM GMT
The PICAXE is does have both true and inverted modes. I've tried using both, though the documentation specifies that when using true, a MAX232 should be used. I have been hesitant to do that since I thought the MAX232 increased the voltage output above (and below) +/-5V.
The Parallax serial LCDs use PBASIC True baudmodes.
Maybe PICAXE calls Idle LO True, there's no microcontroller convention standard for interoperability.· I do not know anything about PICAXE.·
Pic attached, modified program attached.
Does anyone know what typical timing tolerances are for serial transmissions?
Thanks.
Post Edit (newsflash) -- Though the Demo software was written using 9600 baud, you may be pleased to know that the MLX90614 features auto-baud detection: "Auto-baud detection (2400, 4800, 9600, 19.2K, 38.4K) for microcontroller-to-MLX90614 communications".· It occurred to me, all of a sudden,·that it might, but not knowing so till I took a look at the·product·page (of all things)!
Post Edited (PJ Allen) : 2/14/2009 5:56:49 PM GMT
