How to Successfully Set .SXB File Associations in Windows Vista — Parallax Forums
VelocitVelocit Posts: 119
edited 2009-02-13 06:01 in General Discussion
Hi guys,
I had a rather obscure problem with setting .SXB file associations. It was getting annoying having to open SXKey.exe, then select "File," then "Open," then find the file, etc. I know what you're thinking: "just use the Default Programs utility to set the file association." Well it didn't work! I classify myself as a Windows "power user." I know my away around the OS rather well, and it was impossible to select "SXKey.exe" as the default program.
So here's a summary of what's going on:
YOU MAY REQUIRE THIS FIX IF:
  • Your PC uses Windows Vista.
  • You previously had SX-Key v3.2.3 installed on your PC.
  • You upgraded to SX-Key v3.2.92 at some point.
  • You cannot set .SXB files to open with SXKey.exe.
If these conditions aren't true, but you're having trouble setting the file associations, skip to part two of the solution below.
THE PROBLEM:
Somewhere along the upgrade process, a filepath in the Windows registry doesn't get properly updated. This discrepancy prohibits the current SXKey.exe program from being eligible to open .SXB files.
THE SOLUTION:
Part One
  • Click on the Windows icon/Start Menu and select "Run."
  • Type "regedit" into the dialog box and click "OK"/hit Enter.
  • In the left navigation pane, follow the following folder path:
    Computer > HKEY_CLASSES_ROOT > Applications > SXKey.exe > shell > open > command
  • In the right pane, double-click the only key there. It's labeled "(Default)."
  • In the resulting dialog box, replace this string in the "Value data" field:
    "C:\Program Files\Parallax Inc\SX-Key v3.2.3\SXKey.exe" "%1"
    with this one:
    "C:\Program Files\Parallax Inc\SX-Key v3.2.92\SXKey.exe" "%1"
  • If the filepath to your SXKey.exe program is any different, modify the string accordingly.
  • Exit the Registry Editor.
Part Two
  • Right click on any .SXB file and select "Open With" and then "Choose Default Program..."
  • When the "Open With" dialog appears, if SXKey.exe isn't already present, select "Browse" and find the SXKey.exe file.
  • Make sure the "Always use the selected program to open this kind of file" checkbox is checked.
  • Click "OK."
    OR
  • Click the Windows icon/Start Menu and hover over "Control Panel."
  • Select "Default Programs" in the resulting list.
  • Click on "Associate a file type or protocol with a specific program."
  • Select ".sxb" then click "Change program..."
  • Click "OK."
That's it! You should now be able to open any .SXB file in SXKey.exe just by double-clicking on the file.
-Paul
Post Edited (Velocit
  • ChetChet Posts: 150
    edited 2009-02-12 23:31
    Thanks.
    I have been strugling with this on all my computers. I use XP and just do the second part of your explanation.
    Regards
    Chet
  • Shawn LoweShawn Lowe Posts: 635
    edited 2009-02-13 05:14
    VelocitaPaola:
    OMG!!!!! Thank you Sooooo much. You are a Godsend!!! This has been driving me
    CRAZY!!!
    One thing I had to do was goto:
    Start[noparse]:D[/noparse]efault Programs:.sxb and set the editor that way, but it works!!!!
    Once again, thank you!
    Shawn Lowe
    When all else fails.....procrastinate!
  • VelocitVelocit Posts: 119
    I'm glad I could help!
    -Paul
