Are you using a USB to RS232 adapter?
Post up what make/model your using [noparse][[/noparse]that works]..
also post the ones you've tried that failed.
I'll compile the list in alphabetical order and add it to the FAQ's post
Thanx
Smile ... It increases your face value!
Thanx
Dave
Dave Andreae
Parallax Tech Support·
I am running Windows XP Pro and using the premium FTDI cable - US232R-100 - and it is worth the extra $$$.
Craig Eid
www.TriadRD.com
TRW·swap-meet adapter (new in box, $8) works flawlessly on XP and Vista www.aten.com
http://www.aten.com/products/productItem.php?pid=2005022316346005&psid=20070130144911002&pcid=2007013014453002&layerid=subClass7
Brand: HL Model: USB-RS232 Generic blister-card adapter common on Ebay clear/silver cable, blue plastic housings USB 2.0
Post Edited (erco) : 2/12/2009 9:41:56 PM GMT
That sounds like the one I'm using, without any issues.. there is no make or model on the one I'm using.
Works great with the Stamp but I can't get it to work with the SX.
Jeff T.
edit: I had forgotten about this old post, but it needs updating.
The adapter in question did not continue to work, it became "flaky" and would often lose it's connection.
I later upgraded to Windows 7 and never could get it to work with that O.S.
- Rick
Pretty much any adapter using FTDI's chips seems to work. I've used several of the ones they make themselves.
I use the·Parallax USB to Serial (RS-232) Adapter. I have a bunch of them and have never had a problem.
--Bill
You are what you write.
I am getting the no serial port warning jumping up at me.
Sorry I should get kicked for not reading further on to RDL2004's post. I did try this but it was a no go on XP home without major reconfiguration of my usb ports and hopfully not messing up my entire pc.
I think I'll chalk this up as a "HL Blue with silver wire is a No go here" and spend a bit more for a plug and play tommorow when the stores open up.
Post Edited (Ksim) : 3/19/2009 4:24:43 AM GMT
Well worth the $26
BASIC stamp was never detected! If I find my RS232 breakout box I can figure it out later why it does not work. Had similar problem interfacing to my ham rig via USB. The moral of the story - the slowest device in PC - connected via serial port never works on first try.
Cheers
The power switch·is covered in the What's A Microcontroller? Text; which is an educational book that familiarizes users with using the Board of Education and the HomeWork Board. It also covers some relative fundamentals with using the BASIC Stamp and programming in PBASIC. It is possible to download this book from our web site; or it is available in various starter kits, like the Activity Kit, or Discover Kit; but here is a link for the downloadable PDF for a reference.
I hope this helps, and try not to forget, always start with the easy fix first; everyone gets caught overlooking the easy fix from time to time, programming or hardware connections.·
What's A Microcontroller?:
http://www.parallax.com/Portals/0/Downloads/docs/books/edu/Wamv2_2.pdf
Respectfully,
Joshua Donelson
www.parallax.com
Post Edited (Joshua Donelson (Parallax)) : 4/3/2009 2:58:30 PM GMT
I am using a ATEN UC-232A usb to serial converter.· It works flawlessly on xp pro,· but now I have switched to an HP Laptop running Vista 64.· The serial link is not reliable.· If I try to download while a debug window is open, it surely gives me a download failed, hardware error.· If the debug window is closed, then it works about 60% of the time.· I can get just about 100 reliability on download if I put a switch on my Homework Board and stop the program before trying a download.·
My programs are simple servo control in the Homework Board book as I am just starting.
I have tried just about every setting for the port in the hardware manager in Vista for the ATEN port on Com5.· Nothing really helps.
Do you or anyone have any suggestions, or should I get a different USB to serial device?· Please Help.
I tried it with a BS2 last week. It worked for a few hours, then it lost communication. "Stamp not found". It still works with the ADC.
I am now shopping for a new adapter...most likely the one from Parallax, but unfortunately it has to come out of my budget for a new USB BOE
Hello!
I am using the one from Parallax, at the suggestion of Mike. I figured it was my best bet as I am already familiar with the FTDI devices and drivers. I also did run the stamp one I have the same way for a while.:idea:
