coding for boe and ping
Hi
I am using a boe and basic stamp 2 and ping sensor. I am using a robotic arm that is run completely in C++. Up until this we got the boe and ping we used a phidgetts analog interface. We still use the phidgetts board but we need to use boe to get ping sensor readings. My question is, is there a way to send out an analog signal from the reading of the ping sensor, that you get from the boe, to the phidgetts board so we can take that signal and use it in C++. Also we are using 2 ping sensor and I need to get readings from both to the phidgetts board.
Please Help
Thank you
Josh
Please Help
Thank you
Josh
This will allow me to send an analog signal from the boe to the phidgetts board so I can read it on the phidgetts board
josh
