MLX90614 interface to PICAXE
Hello. I'm curious if anyone here has any experience interfacing the MLX90614 infrared temperature sensor to a PICAXE (08M). I have set things up and verified that my PICAXE is transmitting a "0x0, !ID, 0x0", but the MLX doesn't respond. I've also tried other slave addresses that I believe correspond to the defaults, but I've read that all devices will respond to 0x0.
Does the serial interface with the MLX require "T" baud settings and therefore a MAX232 chip? Right now I am using N2400 with the simple resistor network.
Any advice would be much appreciated.
Thanks!
Thanks!
I really respect you and you've helped me a ton in the past but... I have to disagree with you this one time.
The MLX90614 is a Parallax product, and according to my understanding of the forum rules, this is the proper place to ask questions about it.
fredsan42:
Mike's pretty much right though... PICAXE is a competitor to Parallax's primary product lines... so its doubtful you'll get a response here.
Thanks.
Your best bet would be deleting this thread and posting in the new Sensors forum. There are so few posts there that it'll stand out like a sore thumb [noparse]:)[/noparse]
