74hc595
hmlittle59
Hello All,
Two(2) things. Bread Boarded(daughter board) the 75HC595 chip and got my LEDs (RED/GREEN) turning on and off but when the RED Led turns on the Green Led starts to flicker. My thinking is that the bits are being "SHIFTed" thru the the registers causing this to happen. I maybe able to can fix it in software to go thru that routine only once per entry, but is there something else I need to learn about this chip to stop this? (Maybe set latch 'HIGH' after turning LED on or off). I've moved the routines out of the loop routines but no luck. thanks
1) LEDs are flickering ON & OFF when one should be on and the other off
and
2) My Bit count for either LED seems to be ONE(1) off compared to the StampWorks page 130 Drawing.
(00000001) Does NOT work for Pin 1
(00000010) Does work for Pin 1...How am I suppose to count pins (0 -6,15) or (1 -7,15)
'FORGOT TO ADD SAMPLE CODE.........OOOOPPPPPSS.
'This is the Code that deals with the 75HC595
thanks again if you know this chip
I HAVE LEARN SO MUCH...BUT STILL KNOW SO LITTLE!!!
hmlittle59
Post Edited (hmlittle59) : 2/11/2009 12:23:44 AM GMT
and
OffLed CON %00000000 ' Turn Both LEDs OFF
RedLed CON %00000010 ' Turn Red Led ON
GrnLed CON %10000000 ' Turn Green Led ON
ExtAlm CON %00000100 ' FUTURE:::TURN External Alarm ON
gosub RedLedOn
' CODE
gosub GrnLedOn
' CODE
gosub LedOff
'CODE
end
' ------- [noparse][[/noparse] Turn ON/OFF 74HC595 BITs ] ---------
OffLeds:
work = Offled ' "%00000000"
GOSUB Out_595
PAUSE 100
RETURN
GrnLedOn:
work = GrnLed ' "%10000000"
GOSUB Out_595
PAUSE 100
RETURN
RedLedOn:
work = Redled ' "%00000001"
GOSUB Out_595
PAUSE 100
RETURN
ExtAlam:
work = ExtAlm ' "%00000100"
GOSUB Out_595
PAUSE 100
RETURN
Out_595: '
SHIFTOUT DTA,CLK,MSBFIRST, [noparse][[/noparse]Work]
PULSOUT Latch , 5
RETURN
hmlittle59
Low voltage on daughter board caused the 74HC595 to act erratic. Lights now turn on and off like they should. The pin match up to the Bit pattern still has me confused.
thanks
hmlittle59
QA - QH (Pins 15, 1, 2, 3, 4, 5, 6, 7)
Some what strange, but OK. I'll ck it with my meter to make sure my brain absorbs it this way!!! AND IT DID GREAT...
so I'm clear..
(Pins 15, 01, 02, 03, 04, 05, 06, 07)...
equals (Bits 00, 01, 02, 03, 04, 05, 06, 07)...
Thanks again
hmlittle59
