Is this glitch free?
Chad George
I'm sure doing it this way is wrong because there is a short time between instructions where the output is invalid.
Does anyone know if the following code updates pins simultaneously or will there still be a small glitch in the output?
tmp := (tc & $3F) << 1 outa &= (tmp | %11111111_11111111_11111111_10000001) outa |= tmp
outa[noparse][[/noparse]6..1] := tc
I think it does. If it doesn't you could try something like this
I don't know if you can read the value of outa ... do one or more operations with it then assign it back and be safe from unintended consequences.
Thats why I'm a little concerned about doing it this way in SPIN...if it was assembly then I'd know exactly what was going to happen.
I kinda figure the array index notation was designed for this scenario, but I wanted to make sure before relying on it. I am pretty certain it will not affect the status of other pins, but I don't know if it updates all pins in a single atomic action.
So there there is no problem with atomicity in reading/modifying/writing outa. It's yours no one else can get in between. Just don't go setting bits that are not yours.
·"I have always wished that my computer would be as easy to use as my telephone.· My wish has come true.· I no longer know how to use my telephone."
- Bjarne Stroustrup
