Parallax 3.5" Color A/V LCD Pinout
Can anyone please give the pin out for the round 6pin DIN plug that is connected directly to the LCD display? I'd like to plug the LCD directly into my project and skip the long cable with the White, Red, Yellow RCA jacks.
I am curious how 2 video, an audio, and 12VDC power all map to only 6 pins by the way. Assume there must be some grounds shared...but still seems weird.
Thanks for the help.
-Dave
Post Edited (softex) : 2/11/2009 1:34:45 AM GMT
OK, Here's what worked for me. Keep in mind this is the MALE end of the wiring harness which will plug in to what I suspect is a FEMALE 6-pin mini DIN lead to your LCD.
(reverse these pins if you're looking into your female DIN)
6 = 12v red wire
3= GND black wire
4= video1 yellow wire
No guarantee that my LCD is wired the same as yours but it's a standard Chinese garden-variety item.
Good Luck
-Dave
