Hctl 2001-A00
I cannot for the life of me get this chip to work again. I played with it a while back and it kind of worked. I had an 8mhz oscillator hooked up to it and it asks for a 14mhz. I got a 14mhz and wired the chip back up to my BS2 and the darn thing doesnt work. Anyone see anything im missing?· Here is the only code i could find. I think its all correct but if its not im not seeing what is wrong.
Nut shell ( I could be wrong....)
1)· 8 bit interface. chip data·pins in order· 1,15,14,13,12,11,10,9.
2) chip pins 6,7 are the quadrature singals.
3) power is· vss=8, vdd=16
4) chip pin 2 is clock to the the oscillator.
5) chip pins 3,4,5 are contol lines.
6) to get the date from the Chip you need to:
·············· ·············· SEL············· OE·········
················· 1.)········· L················ L················· set inhibit: read high byte
················· 2.)········· H················ L················ Read low byte: start reset
················· 3.)········· X················ H················ Complete inhibit logic reset
attached are my program and·the pdf of the chip
1. The variables are "WORDS" which are 16-bit and should be able to count to 65K. the code that I have will only count to 4095 (12-bit).
2. When the code is run how its posted it will count up to 4095 and loop back to zero. It will also count down to zero and loop back up to 4095. I need it to be able to count below zero. "DELTA" will debug as a negative, what's keeping my total from doing the same?
