SD Card Adapters
Hello,
I need to get a few SD card adapters for use with Propellers. The guys in our office don't have any of these yet.
Could you make a suggestion or two about possible suppliers? We're looking for an adapter socket which could easily breadboard.
Your generosity has to be repaid somehow
See the picture below for an example of how easy it is to breadboard! The pull-up resistors are built in, and only the necessary connectors are brought out to a 6 pin header.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
I have Brian's unit. It is really well made and easy to breadboard. Attached is the photo of his SD Card Adapter from his website.
Whit+
Post Edited (Whit) : 2/10/2009 2:44:05 AM GMT
That's it exactly - even shown with a PE Kit. Could you send two of them - one for me and one for Andy? I'll give mine to Chris after I have a chance to connect it with the Propeller.
That's exactly what we're looking for!
I'm not used to getting free stuff, so this is really great.
I just happened to be packing up another order, so it's out the door in the morning. Good timing!
Brian
If you really get stuck yo can use an old floppy cable and a glue gun to make a connector like the one in the picture (attached)
It's a little rough but will do in pinch.
Aka: CosmicBob
For others, you can buy a SD to microSD adapter. It is an SD card with an internal socket for a microSD. Just glue and wire the SD adapter to the pcb and you have a microSD socket. Mine cost A$7 for the adapter plus a 1GB microSD card at the local Officeworks store.
· Home of the MultiBladeProps (SixBladeProp)
· Emulators (Micros eg Altair, and Terminals eg VT100) - index
· Search the Propeller forums (via Google)
My cruising website is: ·www.bluemagic.biz
Parallax Engineering
That's okay, now we'll all have one.
Ken
<SMIRK>
Having been to Parallax and seen how insanely busy everyone is at the company,
I'll give them a pass... this time... [noparse]:)[/noparse] The SD card is one of the most important
connections to create after video and keyboard.
We'll get you up to speed yet, Ken. [noparse]:)[/noparse] Brian's adapters are very nice.
If all you had is a simple SD socket, they can be attached to a Protoboard very easily.
(A little solder prep at the connection points, and push each pin down with the iron.)
OBC
New to the Propeller?
Check out: Protoboard Introduction , Propeller Cookbook 1.4 & Software Index
Got an SD card connected? - PropDOS
You'll be happy to know that both of my card readers·were broken in over a year ago based on the object in the obex. I only briefly tested them back then as I hadn't yet had a need for so much storage on the Propeller. I am more of a minimalist usually.
which have been written for the Propeller using SD. There's a lot of really neat stuff for it.
Start with Bagger's Manic Miner game, then FemtoBASIC. [noparse]:)[/noparse]
OBC
There's always work to do around the clock, and if we're not careful the regular routine can cause us to neglect what we really enjoy at Parallax.
Good riddance spreadsheets and office tasks . . . I'm hookin' up my PropBot!
Don't forget, the forums has a search feature. Please do your research prior to asking any silly questions!!
-Parsko
Hope you really got the chance to enjoy the Product yesterday!
PropBOT a version of the Boebot with a Propeller board? Or something bigger?
OBC
It was a great afternoon. Thanks for making the directive to do something creative. My time was spent with my plywood robot "PropBot" - not the pre-production model you've seen in our office of the new robot in our training room. My robot is working really well and I was able to spend some time really configuring the sensors to work effectively. Today I'll launch a mini-run of Ping))) brackets on the CNC mill between marketing projects and around lunch so I can more adequately equip my robot.
This is what I've got under control:
HB-25 Motor Control
Ping Sensors, including the software filtering
Wireless modem with 2-meter radios for communication back to my office
Now I'm starting in with the GPS sensor. I need to make that function properly and figure out how to use it for navigation. I'll need guidance on this aspect of the project, perhaps more than the robot will need.
The goal of my project is to sit in the office and watch this robot circle the building to 4 GPS waypoints.
picasaweb.google.com/lh/photo/f9q6UOHRMMaMz4ZAnrnp0A?feat=directlink
I was being "hush" about the wireless stuff.. but since you mentioned it.
Is there any data you can provide on a release date for a product there? [noparse]:)[/noparse]
OBC
Just got a look at the pic of the robot.
Gotta have the Xbee code!
p.s. Glad you got the connector solution, Ken.
JMH
See page 14 of this thread - http://forums.parallax.com/showthread.php?p=654636
The Ping))) brackets are on page 16.
This is Ken's baby...
Whit+
Post Edited (Whit) : 2/12/2009 4:48:32 PM GMT
Just because you got to see the inside of electronics Mecca (Parallax) doesn't mean you have to keep secrets! [noparse]:)[/noparse] Anyway, I don't think it's a potential product, especially since they require a license to operate.
http://forums.parallax.com/showthread.php?p=759557
Don't be so sure about that.. There are a lot of radio amateurs out there..
I need to go back and re-test.. I tried to take it cold without opening the book, and would
have passed if it hadn't been for the antenna wavelength questions..
Yes, I did get to see several new products, [noparse]:)[/noparse] and was told to use my own digression
regarding my sharing what I saw. I figure I'll let Ken and others take lead on the
release of that information. If they post something, I'll share more. [noparse]:)[/noparse]
I will share this.. If you haven't considered the "technicians" HAM license, you might
want to study up on it. You might miss out on little fun down the road. [noparse]:)[/noparse]
OBC
Post Edited (Oldbitcollector) : 2/12/2009 2:50:17 PM GMT
I'm ready...bring it on
de VE1RLL
Aka: CosmicBob
